Scratch Build – In Progress H2O-C7 June 26 Still more Rain! SUX
Discussion in 'Project Logs' started by jhanlon303, 22 Oct 2008.
Guess my weight!
Poll closed 25 Dec 2008.
  1. Less than 2Kg
    5 vote(s)
    14.3%
  2. 2Kg to 3Kg
    21 vote(s)
    60.0%
  3. More than 3KG
    9 vote(s)
    25.7%
  1. Langer
    Langer Jesse Lang
    24 Jan 2004
    You could - and I have - take any old piece of fabric from FabricLand and press it on top of the panels too. It's a cool effect and depending on the fabrics you use can have some very unique properties. I pressed a led zepplin T shirt once while working the night shift
  2. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    I love that carbon bikini :naughty:
    Having all the top & sides all as one assembly, that hinges up together sounds awesome :clap: I wouldn't be cutting boring rectangles for windows or vents, i'd go for some angles or some sort of cool shape... maybe use steath fighters for inspiration on vent styles?
  3. Langer
    Langer Jesse Lang
    24 Jan 2004
    Lol.
    Where's Johnny?
  4. jhanlon303
    7 Sep 2006
    Still here but doing real world things helping Marilyn get ready for her hand surgery.
    13 rooms - 6 bedrooms, 3 bathrooms, kitchen, ... is a lot to get ready so she doesn't have to do much.
    I even learned that sheer curtains are to be hung up damp from the washer and not dried.
    john
  5. Langer
    Langer Jesse Lang
    24 Jan 2004
    Hmm... I didn't know that about curtains... er, thanks for sharing? I think. lol.
    Take your time and do it right - we'll all be waiting patiently.
  6. jhanlon303
    7 Sep 2006
    The cleaning or the Carbon Fibre? [​IMG]
    john
  7. Langer
    Langer Jesse Lang
    24 Jan 2004
    The cleaning, of course... there's nothing scarier than a dissatisfied wife... especially one in pain.
    The carbon can wait.
  8. jhanlon303
    7 Sep 2006
    You guys ever see "Weekend at Bernie's".
    When she got attacked as a teacher and had 3 surgeries on her right hand the Drs. gave her stuff for the pain.
    Put her on the couch I did and she just nods off during conversations with visitors. I'm hoping for the same zombie smiling couch potato snoring on the couch again.
    You could chainsaw in the next room and she wouldn't know.
    john
    PS: Can you scan x-rays. I have the one's from the other hand with the stainless pins(5) holding her together?
  9. marlowdrummer
    marlowdrummer Minimodder
    24 Nov 2008
    Hey,
    nice case, but on to the important stuff.
    Yep, you can scan an x-ray. All you need is a flat bed scanner and a light box. Put the the X-ray on the scanner and put the light box on top, light side down. You have no idea the number of PostDocs that get that one wrong. Sometimes you'll need to place tracing paper between the x-ray and the light box to act as a neutral density filter if there is too much bleed through of light. If it is an old school light box that gets hot, place some spacers to hold it off the x-ray to prevent any possibility of damage. I used to scan x-ray film all the time in my previous job... Sheesh, time change...
    oh yeah, nice work by the way...
    Marlowdrummer
  10. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    Good god what happened!
  11. jhanlon303
    7 Sep 2006
    M was a teacher for elementary school Special Needs children. One of the autistic boys went Van Helsing on her with the wooden pencils. Wrestling in the hallway trying to defend herself. Damaged all the tendons and ligaments in right hand. Ended her career. Wrist ended up having to be fused.
    john
  12. Langer
    Langer Jesse Lang
    24 Jan 2004
    Oh my! That's horrible.
  13. Scirocco
    Scirocco Boobs, I have them, you lose.
    3 Jul 2007
    eeeyowch! Give Marilyn my regards and hopes that her surgery goes well. The box is looking prime, John!
  14. Cheapskate
    13 May 2007
    Ouch! If it had been a normal student, she could have just stomped his face in. (Well, that's how they seem to operate here...)
    They don't hand out the good stuff anymore. You will be quite busy. I hope everything goes well, though.
  15. Jozo
    Jozo This is bit-tech
    14 Mar 2009
    Ouch! Being a teacher can be dangerous even with normal students.
    In my country some students threatened the teacher with an axe so they would get passing grades.
    Hope everything goes OK with the surgery
  16. jhanlon303
    7 Sep 2006
    Being a Special Needs teacher also has it's rewards. Ms. Marilyn came home crying a couple years ago and I ask what was wrong
    "She learned her phone number!"
    2 1/2 years working with this girl and she finally learned the home phone number.
    Patience in bukkit loads.
    john
  17. jesterod
    jesterod What's a Dremel?
    11 Oct 2008
    sadly phone numbers change......
  18. jhanlon303
    7 Sep 2006
    Or some artifact found on a distant planet or moon?
    PSU, optical, HDD in the hinged box with all leads coming down out of MB tray?
    The foam piece is just one of the Exo Terra backgrounds for a terrarium.
    Sit the clear plexi MB tray flat on the foam with enough space around so that the blue CCFL from inside glows underneath. Like the green glow from theTommy knockers film.
    Use the expandable foam from terrarium building to hide the case and build up the top foam in places.
    Solid CF box with no cuts. Hinge it in the rear to lift up and show the H2O features.
    I was cleaning one of the vivariums and remembered this post.
    john
  19. Cheapskate
    13 May 2007
    Ah, You still need holes in the back for air. :duh: I forgot the radiator.
  20. jhanlon303
    7 Sep 2006
    Vent the lower box. PSU fan blowing out - add a nice 120mm in the rear, run the I/O out the wooden box, disguise the fans and I/O with some more foam. If the framework for the MB and pump/rec is made more open - like an erector set - and not a solid plexi plate one should get airflow sucking everything out the wooden box. Leave the channel looking parts of the top foam to act as air intakes too.
    Still playing with it between laundry and pimping the crib.
    john
