Cooling H50 Corsair in stock anywhere ?
Discussion in 'Hardware' started by adam_bagpuss, 6 Jul 2009.
  1. adam_bagpuss
    24 Apr 2009
    cant find this at all in stock ?
    i was under the impression from the reviews and previews that it was supposed to be released for the end of june ?
    anyone know where i can find it ?
    oh UK only please
  2. Lee@Nanopoint
    Lee@Nanopoint Computer says yes!
    27 Feb 2009
  3. ashikamlani
    ashikamlani What's a Dremel?
    11 Mar 2006
  4. adam_bagpuss
    24 Apr 2009
    cool, thanks waiting for more reviews until i purchase though as ive read that the hexus review isnt very good.
    or that could just be bashing from TRUE owners that have been beaten im not sure.
  5. smc8788
    smc8788 Multimodder
    23 Apr 2009
    It still wouldn't tempt me away from a traditional air cooler that costs half as much TBH.
    These things often have their own fair share of problems, and any performance benefit they might show is generally so small it isn't worth the extra price they command over decent air coolers.
    If you need better temps, go for full watercooling. It may cost more than twice as much, but at least it will perform significantly better than air cooling.
  6. adam_bagpuss
    24 Apr 2009
    well the point of this product is that it costs the same as the TRUE which is one of the best aircoolers you can get at the minute.
    it is not designed to compete with water cooling.
    TRUE + FAN = £55-60
    H50 = £55-60
    titan Fenrir = £35
    im actually fed up of my Nero which isnt performing very well in my hot room.
    so i thought that this sealed water unit would be better for high ambient temps rather than a air cooler.
  7. Guest-16
    Guest-16 Guest
    We're still testing our one and we've got another on the way. I will not make a remark on how it is until we've done a long term evaluation equivalent to the Domino ALC in order to assess its durability as well as its performance.
    So far Harry played with it for an hour and it didnt break so that's certainly a good sign!
  8. bagman
    bagman Minimodder
    18 Apr 2009
    I would like know how well the corsair H50 does against the swiftech compact H20-120.
  9. Ady6UK
    Ady6UK Feck Off
    24 Apr 2009
    http://specialtech.co.uk/spshop/customer/product.php?productid=9266
    http://www.novatech.co.uk/novatech/specpage.html?csr-cwch5
    http://www.overclock.co.uk/product/Corsair-H50-High-Performance-CPU-Watercooling-Kit_9023.html (low stock though)
    http://www.tekheads.co.uk/s/product?product=610604 (low stock though)
    In stock at time of post Adam.
    Review:http://www.hexus.net/content/item.php?item=19073&page=1
    Forum user review here: http://www.madshrimps.be/vbulletin/f28/corsair-h50-cooling-unit-64533/
  10. adam_bagpuss
    24 Apr 2009
    most likely not well since its not designed to compete with true water cooling kits. It is howver much much much cheaper
  11. wyx087
    15 Aug 2007
    the Hexus test showed that it's noisier than TRUE, but is able to remove the excessive heat better than TRUE. so it's a winner in my book.
    but those of us with TRUE, it's not a worthy upgrade. but for new buyers, IMHO it beats TRUE hands down. for a little more noise, you get more space around CPU area, easier to install, cools much better with high overclocks/lots heat.
