Motors Hair from exhaust!?!
Discussion in 'General' started by CarlT2001, 6 Oct 2006.
  1. CarlT2001
    CarlT2001 What's a Dremel?
    23 Jul 2004
    Yeah, I intend to. Just thought I would share the hair first.
  2. Darv
    Darv Bling!!
    12 Aug 2002
    Exactly the same thing happened to my Astra. Had me scratching my head for a long while. Especially since it looked like blonde hair. It was also up to a metre long at points and was just traling behind the car without me noticing. :duh:
    It was coming out for a few weeks and then stopped completely. The car seems okay and it isn't really any louder so I've not done anything about yet. This was sometime during the summer.
  3. tkdwarrior
    tkdwarrior What's a Dremel?
    5 Jul 2006
    it's the sound deadening in the silencer. they are usually packed with fibreglass but can be packed with steel wool to reduce the sound a little more. I repacked a MIVV carbon-fibre muffler about a week ago and that looks exactly like the packing that comes out (only a bit more screwed). Just repack the muffle and all should be fine. If there isnt a perforated pipe with hurdreds of small holes through the middle of the silencer it may go toward explaining why this stuff is falling out....it should be there :D
  4. creative8
    creative8 trouble?
    10 Dec 2007
    More hair!!
    OMG ... I have just had the same thing happen today ... did you find out what it was?? Would really like to know how serious it is cause only bought the car today!! Gggrrr!
  5. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    Yeah its just the packing from one of the silencers.
  6. creative8
    creative8 trouble?
    10 Dec 2007
    Brilliant, thanks Xen!! Is it expensive to sort? Only bought the car today : (
  7. Poisonous
    Poisonous Incestuious
    18 Apr 2007
    Looks like my plug hole after a trim.:cooldude:
  8. Xen0phobiak
    8 Aug 2002
    Depends largely on the car, a new backbox for mine is about £12 from most motor factors.
  9. creative8
    creative8 trouble?
    10 Dec 2007
    Cool ... thats good news. It's a Honda Civic Coupe, it's purple and I love it ... apart from the creepy hair that is!! lol .... not a good look!
  10. Amon
    Amon inch-perfect
    1 Jun 2007
    Your muffler needs a haircut.. f**king hilarious... the picture is begging to be lolcatz'd or whatever.
    They're called fart cans. They're on every single Honda and Acura here in Canada.
  11. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    The same thing happened to me on my old Toyota Corolla. but after 420,000km the entire exhaust had rusted out and i just junked the car.
  12. Lovah
    Lovah Apple and Canon fanboy
    10 Jul 2002
    It's sound insulation from your exhaust, most likely the last box. I suggest checking out the rest of the exhaust aswell (pipes, other boxes), check for rust and weak spots. I suggest replacing everything that needs replacing on your exhaust... and do it yourself it will save you quite a bit and it's an easy 1-2 hour job. The box itself should cost less then 100€.
    Good luck.
  13. ou7blaze
    ou7blaze sensational.
    5 May 2003
    Funniest thing i've read all day, LOL
  14. will.
    will. A motorbike of jealousy!
    2 Mar 2005
    I don't know anything about cars, so be nice:
    My Dad has a single seater hillclimb car, inside the exhaust stuff that looked just like that image is wrapped around a pipe that has lots of little circular holes in it. It looked like insulation, but thicker and a lot tougher. Heatproof obviously. Anyway, after he managed to crash the car, he saved a load of parts, including the exhaust, which started doing the exact same thing. My guess is that the pipe with holes in has cracked and is now spewing out what it was previously holding back.
