Networks Half/ full duplex?
Discussion in 'Hardware' started by Alekin, 1 Mar 2003.
  1. Alekin
    Alekin Minimodder
    27 Aug 2002
    Is half duplex 10megs per second an full 100megs per second?
    If thats correct, if i enable full duplex rather than autodetect the speed on both cards, will that make them run at 100megs per second all the time. And then for example, a 600mb chunk of crap would take 6 seconds to go from one pc to another?
    Hope that made sense.
    Thanks
    Alex
  2. bmh.01
    bmh.01 What's a Dremel?
    7 Mar 2002
    Nope, half dupex means data can only travel in one direction at a time, full dupex means it can be in both directions at the same time.
    Also its 100 Megabits a second not megabytes which means that it can theoretically transfer around 10 megabytes a second but the most I have seen is about 8 mb/sec.
  3. RTT
    RTT #parp
    12 Mar 2001
    Um ok well 1st - it's megabit not megabytes. 100mbit/sec is equivalent to 12.5MByte/sec. So 600mb would take approx 50 seconds at full throughput, but usually it's about 10MBytes.
    As for half of full duplex, full duplex is when you can send and recieve at the same time. half duplex is when you are either sending or recieving, not both at the same time.
    edit - beaten too it :D
  4. Alekin
    Alekin Minimodder
    27 Aug 2002
    thanks dudes, cleared all the confusion for me. Ill leave everything as it is then.
    Thanks
    Alex
  5. RTT
    RTT #parp
    12 Mar 2001
    No probs :)
