Half-Life 2 Mod: City 17 Lan-Project --> [www.modding-wurst.com]
Discussion in 'Project Logs' started by TheSchumi, 13 Aug 2004.
  1. TheSchumi
    TheSchumi What's a Dremel?
    13 Aug 2004
    City 17 Lan-Project
    Inspired from Piloux Blackmesa-Project i planned to build a Lan-Optimized Case in a rusty "Half-Life 2 Look". I named my Project "City 17 Lan-Project" because City 17 seems to be the mainplace in HL2.
    MORE HIGH QUALITIY PICTURES ON www.modding-wurst.com IS ONLINE !!!!!!!!!!
    _____________________________________
    Project Log
    First i ordered a "small brother clone" of a Chieftec classic case.
    Afterwards i cut out some Tie Bars and other materials in the front with my "Dremel"
    After that i put Lattice into the hole to get more stability and a nice look from the inside.
    Afterwards i planned the Frontpanel (similarly like Piloux Blackmese Case) with a Ammeter and some Switches on it. I worked with a material called polystyrol-plates :thumb:
    After that i put some screeding compound on the lower plate to get a nice rusty blister look. Aftwards i put some layers "Iron Base Coat" / "Rust Fluid" on the plate.
    Like Piloux i put an old Juwelcase (color: orange) into the hole.
    "Dremelwork" :dremel:
    Now i planed the Main-Control-Panel
    For testing i put some switches and the ammetet into the plate.
  2. The True Zer0
    The True Zer0 What's a Dremel?
    31 May 2004
    Excellent work man.. keep it up!!! :dremel:
  3. liquidhot
    liquidhot What's a Dremel?
    21 Jun 2004
    Looks very nice. I like the front panel.
  4. TheSchumi
    13 Aug 2004
    Now i cut out the frontdoor and put some rivets into the door. After that i will put a lattice with HL2 Logo into the hole. :dremel:
    And now the lattice and the paint: :naughty:
    Afterwards i cut out a HL2-Logo and put it into middle of the door :hip:
    As you can see i painted the whole front. At the top of the last picture you can see ATX-Switch (2nd bolt) and Reset-Switch (4th bolt).
  5. Mosha
    Mosha What's a Dremel?
    31 Jul 2004
    keep it coming!
  6. TheSchumi
    13 Aug 2004
    Now, i painted the panel and the "fan-grill". Maybe i will change the color, cause its not rusty enough, i think so. :duh:
    After that i fill out the lighting-covers on the left side of the panel with hot adhesive. Then i put a red LED into the hot adhesive to get full lightning effect. Later i will attach the Standy-LED and the HDD-LED. :eeek: Furthermore the ammeter received a orange LED.
  7. Satyric_saint
    Satyric_saint What's a Dremel?
    4 Aug 2004
    nice mod I like the front of the case. Can't wait to see the rest of it. :rock:
  8. toyomatt84
    toyomatt84 What's a Dremel?
    1 Jun 2004
    Nice looking case. Although I've seen this mod a bunch already, I still kind of like it. Keep up the good work!
  9. bootupbuddha
    bootupbuddha grunge modder
    3 Feb 2004
    very, very cool. I love rusty pc's........ I seem to be repeating myself. :D
    But where is the rest? You showed a door panel on Pilouxes thread. I think your holding out on us. Come on show us the rest!
  10. baliii_utFaN
    baliii_utFaN What's a Dremel?
    30 Mar 2004
    it's looking nice... i like your hl2 logo on the front door :thumb:
  11. OverFloW
    OverFloW What's a Dremel?
    30 Jul 2004
    +1 :rock:
  12. Buzku
    Buzku What's a Dremel?
    7 May 2004
    Ooh, nice start.
  13. -N4cR-Stigma2K
    -N4cR-Stigma2K Banned
    8 Jul 2004
    What kind of dremel piece did you use to make this?
  14. -N4cR-Stigma2K
    8 Jul 2004
    My god! How do you make these UBER holes?
  15. Acid Burn
    Acid Burn ..look but don't touch..
    14 Mar 2004
    looks great! the front is clean but still looking industrial :D
  16. drinn
    drinn What's a Dremel?
    16 Jul 2004
    Looks nice so far :)
  17. r3men4nt
    r3men4nt What's a Dremel?
    12 Nov 2003
    Nice project im definately going to follow this!
  18. OverFloW
    30 Jul 2004
    whaou, it looks like real! :jawdrop: A-MA-ZING!
  19. D B
    D B What's a Dremel?
    11 Apr 2004
    Wow ! you could not make more real looking bullet holes with real bullets! Nice job with the filler material to make to make the rust blisters, looks like very thick/old metal.
    DB
  20. Bilbo Fraggins
    Bilbo Fraggins What's a Dremel?
    1 Jul 2004
    Good job..
    1 tip THOUGH!!!
    I would take out that molex put some bigger plexy and screw it in from the side and mount the plexy behind the metal. Get the plexy from your nearest hardware store..
    Shouldnt be too hard...
