Storage Half RAID
Discussion in 'Hardware' started by bricks1997, 2 Jun 2010.
  1. bricks1997
    bricks1997 512 bit mental interface
    26 May 2010
    Is it possible to have a RAID configuration on two IDE drives on the same cable and can I keep my SATA drive separate from the configuration. :wallbash: :worried: :sigh: :duh:
  2. saspro
    saspro IT monkey
    23 Apr 2009
    Yes
  3. bestseany
    bestseany What's a Dremel?
    2 Jul 2009
    I wouldn't recommend RAID'ing two IDE disks together on the same cable. Data can only travel to one disk at a time on the same IDE cable, which will cause performance problems.
  4. roosauce
    roosauce Looking for xmas projects??
    12 Feb 2010
    I think both of these are right. Pretty sure you can raid them, but it is a bit pointless if you are using the same IDE channel.
  5. Glider
    Glider /dev/null
    2 Aug 2005
    Unless you are using RAID for what it is... Redundancy...
  6. roosauce
    12 Feb 2010
    Indeed true. I only ever use raid for performance. I back up for redundancy, dont see the need to back up in real time on a home pc. Others may disagree of course.
    I still suspect that RAID1 performance would suffer over a single IDE channel in any case.
  7. bestseany
    2 Jul 2009
    Yes, but performance will still be halved over using 1 disk on each channel.
  8. Glider
    Glider /dev/null
    2 Aug 2005
    Redundant Array of Inexpensive Devices... no performance in there... If you want performance, get an SSD
  9. bestseany
    2 Jul 2009
    You miss my point, why would you want to halve the performance of an already slow disk on an already slow interface?
  10. Pookeyhead
    30 Jan 2004
    Are you suggesting that RAID can not perform? Tell that to my server. It can outperform a great many SSDs... except for seek times, and random small file writing of course. Sometimes for large file transfers... a fast RAID array rocks.
  11. bricks1997
    26 May 2010
    Thank you all for your replies and the advice. I only wanted to use them for back up.
