Windows Halo 1 on Vista 64bit?
Discussion in 'Gaming' started by wyx087, 23 Feb 2009.
  1. wyx087
    15 Aug 2007
    :wallbash::wallbash::wallbash:
    installed Halo 1 on my Vista 64bit to show my friend that this game isn't as old, and graphics are okay.
    but damn thing won't run, no matter what compatibility mode i try, it will not get a display up, simply hear the background music but just displays desktop.
    upon first launch, it did say not enough RAM, with my system summed up as: 3400Mhz, 0MB, 896MB nVidia Unknown.
    anyone got any ideas to get this thing working? (google turned up a lot of Halo 2 stuff) :sigh:
  2. johnnyboy700
    johnnyboy700 Minimodder
    27 May 2007
    You could try looking on the Bungie website to see if there are any issues with Halo CE running on Vista, I played it recently on my XP machine and it was fine.
    The reason you'll find lots on Halo 2 for Vista is that its a Vista only game, it was supposed to be a flagship for the new operating system. Honestly, a 3 year old game (at the time), it was a direct port from an original X-Box game (virtually unchanged so I believe) and with no extras or updates to sweeten the prize - sheesh, who thought that would be a good idea?
    I've tried my X-Box copy of Halo 2 on my 360 and it looks better than the Windows version.
  3. wyx087
    15 Aug 2007
    got it working in the end, choose safemode, then it loads, and select resolutions ect, finally re-launch it in normal mode, and it worked.
    thanks for the reply, damn compatibility issues.
  4. Dark_Master_Dragon
    Dark_Master_Dragon Beware of my lair!!!
    22 Jan 2009
    Have you tried Downloading the Patchs wat am i saying of course the patchs have nothing to do with that XD. Anyways it couldnt be not working because i have a window Vista computer as well and it works fine when i play Halo 1 by the way is Halo one on PC? and is it HALO COMBAT ENVOVLED?:eyebrow:
  5. wyx087
    15 Aug 2007
    the problem was in 64bit, i think.
    got it working in the end, used safemode to configure the game, then ignoring the warning message and launched it.
