Modding .::Hand Airbrushed Mice::. 4 new designs in progress
Discussion in 'Modding' started by Kikbox, 15 Feb 2007.
  1. Kikbox
    Kikbox What's a Dremel?
    5 Dec 2006
    This is a short log because it's really just primer, paint and clear coat but here are the new designs in progress. These mice have been primered and hand airbrushed. You can see the tape is still on them as we are planning to clear coat these today.
    3 of the 4 designs are what I would consider Faux Finishes (painted to look like another type of material)...this is what we specialize in! If you want it to look like stone, wood, metal etc. we can do it with paint.
    The designs you see pictured here can be done on any mouse!
    The Desert Rat - Desert Camo
    The Red Devil - Mean little creature with small scales and sharp pointy teeth!
    Iron Clad - Old Iron with rivets
    Woodie - Pine or maple(we can do other woods)
  2. Echo
    Echo What's a Dremel?
    10 Oct 2005
    How durable are they?
  3. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    Really like that last one, how did you do the wood effect?
  4. Pug
    Pug What's a Heatsink?
    16 May 2002
    *ahem* :read: (sorry Spike. Couldn't resist. ;))
    They're airbrushed by hand, as mentioned.
    Afaik, Stu uses the same airbrush artist as mnpctech - Lin Anderson.
    He's good, ain't he? :hip:
    Echo - once they're clearcoated, they should be pretty good, although I'd imagine they may begin to show signs of wear after a year's heavy use, at least on the buttons themselves, if mine is anything to go by (which wasn't from kikboxes though, I'll add).
  5. mattthegamer463
    26 Nov 2004
    I think he was asking what technique was used to get that wood effect. If he was wondering about what with they were painted, he wouldn't have been so specific. Incredible work though, love that wooden one.
  6. Pug
    16 May 2002
    Well, in that case, check out this Iwata tutorial involving a simple card mask. :thumb:
  7. g3n3tiX
    g3n3tiX Minimodder
    3 Jun 2006
    The wooden one is AWESOME... looks very realistic.
  8. Archtronics
    Archtronics Minimodder
    27 Jun 2006
    out of intrest are you selling these mouses
  9. Pug
    16 May 2002
    He probably didn't want to post a link, as he's a relatively unknown quantity here at this point but I'll vouch for him (and take the heat if posting a link is a no-no).
    http://www.kikboxes.com/ :thumb:
  10. Jamie
    12 Mar 2001
    Yeah I knew they were airbrushed, I just wondered how you do wood with an airbrush.
  11. Pug
    16 May 2002
    Yeah, I know. I was just being humourous/facetious. :p
    Check the tutorial link I posted. :)
  12. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    These are done by one of Stu's staffers. Lins had his hands full with painting Choppers these days :hip:
  13. sparkyftw
    sparkyftw What's a Dremel?
    10 Nov 2006
    I have seen some other their other mouses in person and they are hot.
    I will say these ones look way better then the ones I saw.
    Good work Stu.
