Handbuilt acrylic + watercooling - Optical candy
Discussion in 'Project Logs' started by kong, 15 Jan 2003.
  1. Atomic
    Atomic Gerwaff
    6 May 2002
    Schweet.
    This one's gonna turn out better than your last one!
  2. olv
    olv he's so bright
    23 Sep 2002
    rofl :hehe: always there to make my chuckle eddie!
    nice work there Kong the impressiveness of your work doesn't fade. And while where about different word choices... hows supercajafragalisticexpialadoscious, or how ever u spell it :p
  3. Hippo
    Hippo Pre-dates 5.25" Floppies
    7 Mar 2003
    Hope all that bare copper has a clear coat of varnish/laquer on it :eeek:
    Looking damn fine thou :rock:
  4. kong
    kong cnc-guy
    24 Feb 2002
    Yep, I wanted a system that would allow me to change drives easily, should that one ever break - it is about two years old now!
    And Hippo, yep, I'm using a standard automotive clear lacquer from UK's Halfords.
    edit - oops, thought you were from US!
  5. Carbon
    Carbon Banned
    8 Jan 2003
    Wow, that case is looking very very nice, ive personally never felt like having a clear case.....UNTILL NOW :worried:
  6. Green Soda
    Green Soda What's a Dremel?
    26 Dec 2002
    Who reads what now?:eyebrow::rolleyes:
  7. mod-ern man
    mod-ern man What's a Dremel?
    12 Nov 2002
    Excellent work as usual Kong! Is that one of your super secret fabrication tools on the window ledge behind your case?
    :naughty:
  8. kong
    kong cnc-guy
    24 Feb 2002
    Heh!:miffed:
  9. MaximumShow
    MaximumShow Minimodder
    20 Jan 2003
    total customization is the way to go! A lot of clear cases look kinda dull 'cause there isn't much to see inside that is different than most other cases. With this case, you'll actually want to look inside it!:D
  10. abombss
    abombss What's a Dremel?
    30 May 2002
    Awesome work Kong!
    What kind of router and bits are you using? I saw the Dewalt router, but what model is it?
    Does the acrylic melt using the router?
  11. kong
    kong cnc-guy
    24 Feb 2002
    Welcome to the boards! Not sure on the exact model number or the router, but it's 1100w 1/4" collet and variable speed. Using mostly 1/4" straight bit, the acrylic hardly melts, unless you go too slow. Keep the router moving along, and it's fine. The beauty of the dewalt routers is the electronic speed control, it adjusts the power to the motor, to keep the spindle speed constant, unlike cheaper amchines which will slow down if you push too hard.
  12. kong
    kong cnc-guy
    24 Feb 2002
    Hey, Five Star rating! Cheers guys, I guess I better pull my finger out and get some more work done!
  13. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    The case looks great. Did you finally manage to get that drill bit out, kong?
  14. kong
    kong cnc-guy
    24 Feb 2002
    Nah, the drill bit stayed! Check page 4 for the faceplate that hides it!
  15. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    adds character anyway... like those little capsules they would put in the keystone of an old building... out jumps a frog and sings "Hello my honey, hello my baby...hello my ragtime gal... send me a kiss by wi...." *yanked of stage*
  16. fivecheebs
    fivecheebs Dont panic!
    19 Feb 2003
  17. DeX
    DeX Mube Codder
    22 Jul 2002
    Are you going to going to leave that faceplate partially bare? I think it would look better completely covered :worried:
    I thought it was supercalafrajalisticexpialadoscious
  18. kong
    kong cnc-guy
    24 Feb 2002
    I like that look personally, sort of follows the "see-thru" theme. Although you can see that ugly bit of cd case aluminium in that shot, in real life, when viewed from above, it doesn't show.
    Eddie_Dane, you never fail to make me laugh!
  19. Jack
    Jack Minimodder
    22 Dec 2002
    Agreed i like the look of it clear but the dull grey alui is a poblem why not get a spray paint that match's the color!
    But saying that I like the clear look:):thumb:
  20. Nexxo
    23 Oct 2001
    That is an outstanding piece of work. I also like the original look: not many copper and acrylic cases out there. Quality stuff. :thumb: :dremel:
