Blogs Hands-on with NZXT's Aer RGB fans
Discussion in 'Article Discussion' started by Dogbert666, 30 Dec 2016.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  2. Vault-Tec
    30 Aug 2015
    Nice review man. I think I prefer those to the Corsair, though far too rich for me :)
  3. Hustler
    Hustler Minimodder
    8 Aug 2005
    I can't put NZXT fans in my Corsair 450D case!!!
    Some things just aren't done.
  4. megamale
    megamale Minimodder
    8 Aug 2011
    What truly annoys me is the proprietary format of it all. Why can't they play ball? I have a Phanteks case that is compatible with the Asus Hue, so realistically I can't use any of these fans.
  5. GrahamC
    GrahamC What's a Dremel?
    21 Jun 2006
    Can the light strips be a different colour than the fans? that would be cool. If it all has to be the same, dare I say, too much bling.
  6. Combatus
    16 Feb 2009
    Yes they can - each module, be it a fan or LED strip is recognised independently in the CAM software.
  7. GrahamC
    21 Jun 2006
    Great, thanks for the info.
  8. gosh
    gosh Minimodder
    20 Oct 2009
    a) how's the actual cooling and
    b) can't you just ring one of these RGB strips around any fan ?
  9. GrahamC
    21 Jun 2006
    Don't know about cooling but the fan frame and ring look shaped to me.
Tags: Add Tags
