hangs on restart
Discussion in 'Hardware' started by NOTPENTIUM, 22 Mar 2003.
  1. NOTPENTIUM
    NOTPENTIUM What's a Dremel?
    12 Jan 2003
    Hello,
    on this new system running win98se cuz i just like it. When i restart it goes off, then the bios splash comes up like normal. But then when it gets to the flying window screen it just sits there until i hit reset. Then it boots up fine when i choose normal mode
    any ideas
    MSI K7N2
    AMD XP1800+
    WD 40 GB HDD
    TEAC FLOPPY
    AOPEN CDRW
  2. Moo
    Moo What's a Dremel?
    19 Aug 2002
    Have you reinstalled Windows? It doesn't like too many things changed in one go. Could also be a driver issue.
    If windows starts to open it sounds like chip/mem/hdrive are ok, try starting in basic mode, I think it involves holding down F5 or ctrl while loading, check in control panel > system for any mising drivers or warnings.
