Hard Disk Help
Discussion in 'Hardware' started by clevoir, 19 Jun 2003.
  1. clevoir
    clevoir What's a Dremel?
    30 May 2002
    Help
    Recently changed motherboard, and rather than reinstall Windows XP from scratch, I did a repair install instead
    PC is working fine, and a couple of weeks later, I wanted to create a Ghost backup of the hard disk, however this crashes half way through stating that it can't read from certain sectors on the hard disk
    Running CHKDSK notes that there are file system errors, however when I run CHKDSK with the /F switch to fix the errors, the PC crashes with the following stop messages
    STOP 0x0000007E (0x0000005,0xF7A7151D, 0xF&966C34, 0xF7966934)
    and
    STOP 0x0000007E (0x0000005,0xF7A6551D, 0xF&966C34, 0xF7966934)
    I have tried reinstalling Windows XP using the repair option, but this has had no effect on sorting the problem
    It's a Seagate 20GB drive, tried running their online system file checker, PC locks up solid when it try to repair the errors. Tried their desktop disk untility, which boots from a floppy, but this too crashes
    Does this sound like a dead or drying hard disk?, as the PC works fine apart from this. I am tempted to carry out a low level format and try and reinstall Windows XP from scratch, can anyone recommend a good utility for doing this??
    Also, whenever I reboot the PC, my raid array (which is served from a seperate PCI Raid card) keeps getting reported as broken, and has to be rebuilt. This seems too much of a coinsidence, could it be the power supply on it's way out
    Hard disk and raid array were working pefectly in the PC before a changed the motherboard, and for some weeks since it was changed
    New motherboard is a GA7DXR, and the power supply is a generic 400W model from Maplins
  2. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    It does sound like a dying hard drive, but the important part of the BSOD message is the line after the STOP message. What is it?
  3. Tribal Dragon
    Tribal Dragon Insomniac modder!
    17 May 2002
    well... maybe your disk is dying... maybe not....
    got there and grab diagnosis program and and search a little for the low level format utility. Run first the diagnosis app and if things are not sorted, low level format the disk, then format the disk and reinstall windows. everything should work. if it doesn't, the hdd is dying and you might consider to buy another one before all your data is dead...
