Hard Disk Question
Discussion in 'Hardware' started by Shadowed_fury, 27 Oct 2004.
Cooled or Standing Hard Disk? Curious...
  1. Cooled with 80mm's
    30.3%
  2. Cooled with 120mm's
    17.1%
  3. Watercooled
    1.3%
  4. Other (please post)
    3.9%
  5. Not; Left standing in a drive bay.
    39.5%
  6. Cooled with 92mm's
    7.9%
  1. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Are your Hard Disk(s) cooled in any way?
  2. Mister_Tad
    27 Dec 2002
    ive got 92mm fans blowing across my drives
    are you discriminating against types like me with that poll? :eek:
    /edit: cheers, voted :thumb:
  3. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    Mine are cooled with 80mm's at the moment, but will be cooled by a singe 120 once i've migrated to my new case, after I finish building it.
  4. Guest-16
    Guest-16 Guest
    cube n all, so 92's
  5. riluve
    riluve What's a Dremel?
    29 Jun 2004
    Ha! I just bought one of these sweet things. It converts three 5.25” bays into four 3.5” HDD bays and adds a 120 mm fan to cool the four drives.
    I especially like it because most of my machines aren't even in cases, they are just sitting on tables or a horizontal surface (lol - yes even the floor). Soooo, this handy device provides both cooling and a safe haven for drives that might otherwise just be sitting around.
    Also, if you are building a case from scratch, it provides great additional flexability.
  6. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    cooled by a single 120mm :)
  7. Shadowed_fury
    21 Nov 2003
    hehe, course not mate, just 92's are harder to come by in standard cases.
    :D *honest*
  8. severedhead
    severedhead What's a Dremel?
    19 Dec 2002
    Another with 92s. Got couple of 'em suckin air over my drives.
  9. Stompy
    Stompy What's a Dremel?
    16 Aug 2004
    Absolutely nothing atm, since its an old IBM 20gb drive, and my case doesnt have a fan spot in front of the hdd bays.
    But when i get my Maxtor DM10 (they run very hot), I'll be sticking a chopped up old heatsink to it and adding a 60mm fan.
    What bit actually needs cooling? I'm guessing it's the motor bit?
  10. cool_dude
    cool_dude Minimodder
    26 Aug 2004
    120mm is going to be cooling my hard drives.. but currently im using a 80mm fan :)
  11. 0013
    0013 What's a Dremel?
    7 Mar 2004
    1× 92mm over and below both my HD's
  12. riluve
    29 Jun 2004
    the whole thing. if the motor gets hot, the heat creeps through the entire unit.
  13. JuMpErFLY
    JuMpErFLY Minimodder
    13 Mar 2003
    80mm cooling 2 drives in the lower bay, nothing cooling the upper drive near fdd :)
  14. aaronrkelly
    aaronrkelly What's a Dremel?
    1 Jan 2004
    My Raptor in my desktop is in its own drive bay with its very own 80 mm fan blowing on it.
    My server has a 120mm fan blowing across the 3 - 200 gb WD SEs.....they stay fairly cool.....about 27 degrees
  15. TMM
    TMM Modder
    12 Jan 2004
    in my main rig i have one hdd in a 5 1/4 bay with mesh on the front of it, the other in 3 1/2 drive cage of its own with the two 3 1/2 drive covers removed and replaced with mesh. the exhausts in my case are powerful enough to pull air in over the hdds ;)
    in my server (1800+) i have a 80mm fan blowing over the drive (WD 800BB) as its gets damn hot (50*C) without extra cooling.
    the other computer (3000+) hasn't got any hdd cooling but the case is fairly large and the hdd doesn't get very hot anyway. THe exhaust fans pull enough air into the front of the case and presumeably over the hdd anyway, but the suction power is nothing like my vacuum cleaner (2500+) :naughty:
  16. Stompy
    16 Aug 2004
    So if i stick a heatsink to the motor to get the heat away from it quicky, and then have a little 60mm fan blowing on the heatsink, would this do?
    for a Maxtor DM10 120gb SATA
  17. Mister_Tad
    27 Dec 2002
    nope
    the drive gets hot from the platter, the motor, the bearings: everything
  18. riluve
    29 Jun 2004
    :confused:
    It all comes in a case right? just stick the HS to the case.
  19. TheCleaner
    TheCleaner Back again...
    5 Jul 2004
    I modded a 120mm fan into the front of my case, the hdd sits right behind it, and stays cool
  20. Will
    Will Beware the judderman...
    16 Jun 2001
    As above...panaflo L1As at 7v :)
