Hard Disk Slow
Discussion in 'Hardware' started by Mr T, 20 May 2002.
  1. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    Ive got a Maxtor 32049H2 Hard Disk (http://www.maxtor.com/products/DiamondMax/DiamondMaxVL/QuickSpecs/42079.htm) and i was copying files accross from one partion to another andi realised it took slightley over 10 minutes to copy 3.45Gb of mp3's from one drive to the other. I thought surely somethings wrong :rolleyes:. Its definately an ATA100 board and cable so why is it so slow ?
    Or im i just worrying about nothing and it probabley just is that slow ?
  2. Mr T
    14 Nov 2001
    Doesnt matter i think i found the problem :)
    Mind The Doors
  3. Mr T
    14 Nov 2001
    After degrag is still took 6.59 Minutes to transfer 2.5gb and i was talked to RTT and he says it sounds slow any ideas ?
  4. bAnTAi
    bAnTAi What's a Dremel?
    19 May 2002
    well....depending on which drive it's going to....they look pretty full...the fuller the slower
  5. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    try runnin a benchmark program like sisoft sandra to see what kind of speed you get for your hdd...
    or even try out the new 3dmark that is for apps only...
  6. felix the cat
    11 Jan 2002
    just to see whether that was way off, i did a test on mine...
    took 8.3 mins to transfer 2.7gb from one partition to the other on my IBM Deathstar....
    so i guess your should be fine, but then again i cant say whether ur hdd is a lot better on mine....
  7. Guest-16
    Guest-16 Guest
    from partition to partition it will be slow cause ur limited by the rate at which the heads move, not from 1 disk to another which is in sync if its across 2 channels
  8. bAnTAi
    19 May 2002
    oh right...yeah....its probably fine if they're partitions....cause its slower than hard disks
