Modding Hard Drive Clock
Discussion in 'Modding' started by jezmck, 2 Sep 2005.
  1. jezmck
    jezmck Minimodder
    25 Sep 2003
  2. Nexxo
    23 Oct 2001
    OK, that is WAY cool!
  3. mattthegamer463
    26 Nov 2004
    howd they do that? is it like one of thsoe spinning clock thing s you see at radioshack?
  4. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    Ooh, /me wants
  5. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    yeah, might have to make one now..
  6. Mattt
    Mattt Minimodder
    12 Nov 2001
    im pritty certian im going to make one, got a basic stamp board thats not doing much atm so i should be able to control it with that.
    all i would need to make is the IR sensor input and the LED output.
    got 2 hdds that i was going to throw away.
    e-mailed him to ask if i can have the code in english rather then HEX. cos im not 100% certain how the clock works.
    i think it calculates the speed of the platers based on the time interval between IR detection then when the plater is in the correct position, based on a time interval it turns on the LED colour / colours for that hand.
    hopefully my one will be able to have 3 LED outputs as well so hopefully i can have RGB hands. :D
  7. GuardianStorm
    26 Apr 2005
    the best thing to use as the sensor would be an old mouse they have a U shaped usint that is an IR Emitter & Sensor built in one, very useful and easy to wire up :)
