Cooling Hard Drive Cooling
Discussion in 'Hardware' started by Callum, 14 Jul 2006.
  1. Callum
    Callum What's a Dremel?
    4 Apr 2006
    I need to cool my hard drives (at the very least), but know next to nothing about cooling. If I could get a general overview, so I don't get ripped off in the store, that would be great.
    Some questions:
    Do all hard drive cooling devices require a 5.25" drive bay?
    What brands should I be looking out for? (Several to choose from would be nice, as we can't get everything here).
    How much should I be looking to pay?
    While I'm at it, should I just go the whole hog and upgrade from the stock fans on my CPU, Northbridge, and GPU?
    Again, what brands and prices?
    Or should I really go for it, and go for watercooling? Is it difficult and dangerous? Especially for someone who hasn't even upgraded to air?
    Anything else I should know?
    If this is too little research done by myself, could someone at least point me to good sites for cooling, so I can look at prices?
  2. Skylined
    Skylined Minimodder
    3 May 2003
  3. Callum
    4 Apr 2006
    Well, I've just been down to the shop to have a look, and all they have are some unbranded fans attached to brackets to screw on. This won't help much, as I have a fan blowing over them anyway.
    I will spend whatever is necessary on the hard drive coolers to get the best I can.
    The other cooling, well... I don't know anything about the options...
    I would imagine there is room in my case, I don't have all that much in it.
    Yes I am willing to mod and invest time.
    Silent is nice, but not really necessary.
  4. Marci
    Marci Ex-O-CuK / ThermoChill
    9 Aug 2002
  5. Archtronics
    Archtronics Minimodder
    27 Jun 2006
    can i ask what hard drive you have got and what case its housed in
  6. THEkorean
    THEkorean 42
    10 Jun 2005
    id say... go with air, its not worth the trouble and money to cool your hardrives (assuming thats more than 2) and all your components with water. as for your questions, no not all HDD coolers require a 5.25" bay but the nicer ones tend to take up the 5.25" bay, as for brands, i would highly recomend zalman they have pretty nice and quiet cooling solutions for almost anything in your case, cooler master also has some nice Hard drive coolers (cooldrive series), i dont know about computer retail stores near you, but the ones near where i live are really shite and expensive id say you shop online, you would probably get better prices online. also, f you havnt used aircooling yet its gonna be loud ><
  7. Fr4nk
    Fr4nk Tyrannosaurus Alan !
    12 Mar 2005
    Hard drives gernerate heat from the sides, try getting a fan to blow from the side.
  8. Skylined
    Skylined Minimodder
    3 May 2003
    Then I would use the heatsink method. :)
    If you take your case from one place to the other, just use some screws or something to secure it.
  9. Callum
    4 Apr 2006
    Ordering online is no good. The companies that even ship here charge so much on shipping, its ludicrous.
    But at the same time, I haven't been able to find anything but those fans here.
    When I was in the capital though, I think I saw a Coolermaster hard drive cooler. I was a bit confused as to how it worked. Looked like it simply enclosed the hard drive.
  10. LVMike
    LVMike What's a Dremel?
    11 Aug 2004
    it has a fan that blows onto the drive thats all. it just looks nice... (if thats your thing)
  11. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Look in his sig
    AMD Athlon 64 X2 3800+ :: DFI LANParty nForce 4 SLi-DR Expert :: 2 x 1 GB Corsair TwinX XMS PC3200 DDR RAM :: XFX GeForce 7900 :: Western Digital 36GB Raptor and 250 GB Caviar :: Creative X-Fi Platinum :: Enermax Liberty 500W :: Sony DRU-810A DVD+/-RW :: Coolermaster Centurion 5
  12. GiGo
    GiGo was once a nerd.....
    12 May 2002
    I've got 10 HDDs in my rig and they run hot and to cool them down I use those 'fans on brackets' and they do work!
    I have a 120mm cooling the front 5 drives (side on) and then 2 of those fan things under 2 of the other 5 and they all run about the 35C
    Regards
    GiGo
  13. crazydeep74
    crazydeep74 What's a Dremel?
    25 Jul 2005
    I have 9 HDD's and nothing to cool them :)
