Hard drive- Died? NEED HELP RIGHT NOW!
Discussion in 'Tech Support' started by rito, 1 Jan 2008.
  1. rito
    rito What's a Dremel?
    19 Sep 2007
    Ok I came to play a game the was on my hard drive and i noticed my folders gone I tried to open up a folder and i wanted me to format the hard drive, i tried running a scan on the hard drive and it crashed the computer. i shut down the computer and tried different things changing the cable and other stuff. now the hard drive is make loud clacking nosies, is it died? Can i get my 70g of data off it?
    now i'm getting a grub boot: "error 21" what should i Do?
  2. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    if its making loud noises, and it wont work at all. its time to buy a new one.
  3. rito
    19 Sep 2007
    the error 21 is a grub boot loader error thats happening because i dont have all three hard drive installed
  4. OleJ
    OleJ Me!
    1 Jul 2007
    The drive is gone bye-bye. Getting your 70GB of amateur video and private cd-rips back will cost you A LOT of money (we're talkin 5 digits at least). And recovery is uncertain since the write heads have most likely been scratching the surface (the sounds coming from it).
  5. rito
    19 Sep 2007
    I just went and bought a 320 gb hard drive for $75 :)
  6. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    If the data was important, but you don't want to spend a fortune on professional recovery you could always try to use Get Data Back and hit the drive against a table or something while it's running. (the clicking should stop) In most cases it won't work or even make things worse, but you can get lucky. You got nothing to lose.
  7. rito
    19 Sep 2007
    god. i tried putting the hard drive verticly and it worked perfectly i can access all my files and stuff, however it still make odd nosies at time.
    was my raid card to blame?
  8. OleJ
    OleJ Me!
    1 Jul 2007
    no :)
  9. rito
    19 Sep 2007
    WTF, ok so it turns out i can read the drive through linux but not windows, Should i just lay in the fetal position for several hours?
  10. Shatylle
    Shatylle What's a Dremel?
    21 Nov 2007
    I would ditch the drive either way..
  11. Smilodon
    25 Mar 2003
    Just get out what files you want while you have the chance and throw away the drive afterwards. It's broken and can never be trusted. (Actually, you should NEVER count on that a disk won't fail. Always keep backups. Eventually ALL disks fail.)
  12. rito
    19 Sep 2007
    i just kinda mad because i spend $99.98 to get a dvd burner and a hard drive, only to get my old one to work
  13. Thacrudd
    Thacrudd Where's the any key?!?
    27 Oct 2006
    Get what you can off it and get rid of it. Smilodon knows what he's talking about. I have been up this road before and loosing 4 years of memorable videos and pictures is not very fun. Back it up and buy a new one.
  14. chrisb2e9
    18 Jun 2007
    its not working. sure you can get data off of it, if you hold it vertically, but thats like having a shoe with a hole in the heel of it. sure you can walk on your toes for a while to keep water from getting in, but sooner or later that part of your shoe will wear out too. in other words, it wont work forever.
  15. rito
    19 Sep 2007
    god, my computer hates me, now my cdrom drive wont read cd in windows
  16. chrisb2e9
    18 Jun 2007
    maybe its in league with the harddrive.
  17. OleJ
    OleJ Me!
    1 Jul 2007
    LOL
  18. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Is it the new one or an old one? Old CD drives do actually wear out and get reading problems... My 5 years old LG DVD-CD reader doesn't access all discs if they are even a bit bad.
  19. rito
    19 Sep 2007
    It's an old one, so it doesn't surprise me.
