Electronics Hard Drive Selector Switch
Discussion in 'Modding' started by culley, 9 May 2007.
  1. culley
    culley What's a Dremel?
    12 Jul 2006
    Ive been researching possible methods todo this. I come up with a master pin switching method but i was wondering if anyone has done it with a power switch instead of switching the master pins?
  2. g0th
    g0th What's a Dremel?
    12 Apr 2005
    Why don't you take the +5V and +12V supply rails of two seperate hard drives to a DPDT switch, so that only one is connected to the PSU at once?
    Set them both to master, if they're on the same PATA channel.
    That'll work, but certainly won't be hot-swappable.
  3. bender386
    bender386 What's a Dremel?
    5 Jan 2006
  4. culley
    12 Jul 2006
    What about a SPDT switch??
  5. mattthegamer463
    26 Nov 2004
    I think it needs a DPDT switch so it changes the rails from one drive to the other, not just turning one drive off. That could work but you'd need two switches.
  6. g0th
    12 Apr 2005
    To switch both the 5V and 12V rails between two hard drives, you'll want a DPDT switch.
  7. mattthegamer463
    26 Nov 2004
    You should get a DPDT knife switch and put a picture of the one OS logo at the top and the other at the bottom, so you know which your flipping to, and make it dramatic with the knife switch.
  8. culley
    12 Jul 2006
    will update once parts are ordered, thanks for the help & info.
  9. 330td
    330td Minimodder
    12 Aug 2004
    It could work with 1 switch and some relay
  10. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    1 drive + bootloader?
  11. mattthegamer463
    26 Nov 2004
    Correct, but that would be a lot more work than just simply popping in two switches. If he had a relay circuit lying around then it could be a viable solution for him though.
  12. g0th
    12 Apr 2005
    Or just use a single DPDT switch... :rolleyes:
  13. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    Ive had a DPDT switch running on my server for years. Works great. Even added some leds to let me know which drive im using.
