Modding Hard Drive Window (56K warning)
Discussion in 'Modding' started by Cipher_UK, 12 Mar 2003.
  1. chambochae
    chambochae What's a Dremel?
    11 Nov 2002
    the top platter still has an arm thingy, which is very very close to the surface of the top platter, so even if there is no data the extra height given to the platter by the paint would probably stop it spinning or clog up and go all over the place
  2. Atomic
    Atomic Gerwaff
    6 May 2002
    The arm would just scrape off the paint when it swings over the platter, causing UV paint to fly around the drive... could look cool if you don't mind completely killing the drive :D
  3. Astrum
    Astrum Dare to dream.
    8 Mar 2002
    You might as well not. You would have to tape the edges so the paint doesn't go under the first platter. And even then, there is always the possibility of the paint cracking and a chip flying into your platter.
  4. Yoda
    Yoda What's a Dremel?
    26 Jun 2002
    You could dab a bit of UV reactive paint on the back side of the arm. That would look really neat under a black light at night.
    I think that would work and not cause any serious damage.
    Paint on the platter would be kinda messy as mentioned by those above me.
    by the way....
    How do you know there is no data on the top platter?
  5. zackerouac
    zackerouac bring it
    23 Sep 2002
  6. Cipher_UK
    Cipher_UK What's a Dremel?
    12 Mar 2003
    No head on the arm.
  7. pranks7er
    pranks7er mange tout
    25 Dec 2002
    actually theres no data on the top and bottom platters, i know because I did 'A Level' Computing last year and we were taught that, the platters top and bottom are there to stop dust etc getting into the main part of the drives.
  8. Cipher_UK
    12 Mar 2003
    So much for modern education - the drive in question only has ONE platter with 1 data head on the underside!:naughty:
