Electronics Hardcore fanbus for hardcore blower.
Discussion in 'Modding' started by Xen0phobiak, 14 Jul 2004.
  1. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    For this mod linky
    I need a power supply/fanbus capable of adjusting between about 5 and 12 volts, providing about 5 amps while @ 12v.
    If that isnt feasable, a way to drop the voltage down to around 5 volts, so I can use a switch.
    Can anybody help me with the designing and/or making of such a circuit please?
  2. Risky
    Risky Modder
    10 Sep 2001
    Hmm, could you mod in a second PSU to the case. maybe Matx would do as you're after 60W on the 12V line. Maplin sell 10A switches, DPDT so you can have some indicators.
  3. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Easy-peasy, but for a linear control you've up to 13W of heat to waste, so a PWM controller might be cooler. :hip:
    With them motors you'll need a nice fat diode (1N5401, 10p to you) across the motor, connected as shown in the circuit on this page.
    /50 bonus points for triple pimp :rock:
  4. Xen0phobiak
    8 Aug 2002
    Well deserved points there, thanks m8 :D
  5. kbn
    kbn What's a Dremel?
    17 Mar 2004
    rapidelectronics sell lm338T 5A variable regulator which would do it.
    they also sell "MIC45xx 200kHz step down voltage regulators" here but I dont know how to use them. They cost a lot more in comparason but waste a lot less heat - 77% efficient.
  6. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    You wouln't really need a PWM step down regulator since they are mean't for outputting smooth voltage, but when you PWM a fan, you dont need smooth voltage. So you can use something as simple as a 555 and a mosfet (though you won't get 100% power with a single 555, you can get 100% with two somehow).
  7. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    How about a simple PIC PWM generator + MOSFET driver.
    somthing like a 16F6xx built in 1 channel PWM is all that would be needed.
    LED + Switch control.
    Maby even try and make it seek an RPM n replicate this for the mobo?
  8. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    Or better yet use a small PIC12F675 with a pot connected to one of the A/D inputs, and code your own PWM routine.
    Velleman make a PWM kit for controlling loads upto about 6.5A. Kit - K8004. I have one here pre-built if you want to buy...
  9. kbn
    17 Mar 2004
    Yes but you could smooth the output after with caps..
    If its not smooth then the fan will be almost more niosy than without being turned down, because the stopping and starting makes it niosyer.
    How can a mosfet and 555 timer be used to do pwm?
  10. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    Err, if the PWM is fast enough, you don't have the growl (in a frequency you can hear).
  11. cpemma
    cpemma Ecky thump
    27 Nov 2001
