Harddisk won't show up
Discussion in 'Tech Support' started by JCG, 26 Aug 2006.
  1. JCG
    JCG What's a Dremel?
    1 Dec 2005
    today I bought and hitachi desktar (164 GB) to replace my 20 GB slave harddisk. But when put it in the computer it shows up in Bios and in My system but not as a harddisk in My computer.
    I've checked all the cables and triple the slave settings, but still nothing :(.
    The OS in Windows XP home sp2.
    Does anyone know how to fixed this is problem?
  2. yatesy
    yatesy What's a Dremel?
    10 May 2005
    Right Click on My Computer
    Manage
    Disk Management
    Scroll to your new hard drive, and partition it.
    That should just about do it
    Yatesy
  3. JCG
    1 Dec 2005
    Thank you, he busy formatting now. problem solved.
  4. yatesy
    10 May 2005
    Good to hear :D
    Yatesy
  5. JCG
    1 Dec 2005
    :waah: problem no. 2
    If I format the harddisk, it starts to format but in the end it says "format not completed", in dutch. What could be wrong?
  6. TheoGeo
    TheoGeo What are these goddamn animals?!
    10 Jun 2003
    try downloading fdisk or some other hard drive formating program like partition magic and see if you can do it through there.
  7. Solidus
    Solidus Superhuman
    26 Dec 2005
    Lmao i love you Yatesy. You fixed the exact same problem for me a few days ago.
    Meloveyoulongtimenow.
  8. thefishingangler
    thefishingangler What's a Dremel?
    31 Aug 2006
    Same problem
    Howdy.
    I have the exact same problem but, I don't want to format the drive as it has data I need.
    Anyone have an idea how to enable this disk to be seen by "My Computer" as it is listed in both the BIOS and Device Manager?
    Thank you much.
  9. DougEdey
    5 Jul 2005
    Right click on the drive and goto mount in adminstrator properties.
    Basically the same method as before but a different option.
  10. TheColdLord
    TheColdLord What's a Dremel?
    21 Apr 2006
    WTF????
    Same problem here...I just bought a new WD 300GB HDD...it is shown in Speedfan but it isn't shown as a hdd in my computer.....pisses me off! Same Windows SP2
  11. DougEdey
    5 Jul 2005
    Have you done the same as the OP? Gone to Admin tools, drive management?
  12. TheColdLord
    21 Apr 2006
    Erm.....srry but how do you partion a hdd :blush: :blush: :blush: ......just click on initialize disk?
  13. TheColdLord
    21 Apr 2006
    I have another question.....I am now formating the partition, but it says that there is 279GB of space available....the hdd has 300GB...so I do not understand where 20GB are gone???
  14. DougEdey
    5 Jul 2005
    If you look at the drive it will say something like
    I.e. 1GB = 1Billion bytes (UK)
    But in actual computing terms, your OS determines size using GibiBytes (GiB)
    so 1GiB = 1073741824Bytes
    so your hard drives 300,000,000,000Bytes becomes 279.3967723846435546875GiB
  15. TheColdLord
    21 Apr 2006
    Allright....you just killed me :p And isn't there a prog that could maybe give me at least 10GB.... I mean... I have another hdd a Maxtor 160GB and it has 152GB on it......
  16. TheoGeo
    10 Jun 2003
    Its the way it is. Computers define 1GB as 1024MB and 1MB as 1024KB etc, However hard drive manufacturers use 1GB = 1000MB etc to simplify things and always have, this means that the values on the hard drives are correct, but a different definition. The effect this has is less on smaller hard drives so your 160GB drive is a little closer.
    You havn't lost any storage, there is just less there than you thought.
  17. hitman012
    hitman012 Minimodder
    6 May 2005
    The larger the hard drive, the more space you lose due to the GB/GiB thing.
    80GB = 74GiB
    120GB = 111GiB
    160GB = 149GiB
    200GB = 186GiB
    250GB = 233GiB
    300GB = 279GiB
    400GB = 372GiB
    500GB = 465GiB
