Other Hardest known metal on earth!
Discussion in 'General' started by jason scott, 11 Apr 2010.
  1. jason scott
    jason scott What's a Dremel?
    11 Apr 2010
    Hi there,
    I want to know that which is the hardest known metal occurring naturally on earth and if anybody can provide some information about the hardest known metal artificial one also does these metals support metal stamping or not. Please if anybody can provide the information about this question then I'll be very thankful.
    Thanks
    Jason Scott
  2. Freedom
    Freedom Minimodder
    27 Oct 2004
  3. D-Cyph3r
    D-Cyph3r Gay for Yunosuke
    31 Aug 2008
    Doublehardshutupyouslagmuppetanium
    EDIT:
    My balls are made of it.
    Moyo2k likes this.
  4. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
  5. ch424
    ch424 Design Warrior
    26 May 2004
    1. Strength isn't the same as hardness.
    2. Most of the top ten results on that page are wrong.
    Jason, when you say "naturally occurring", what you do mean? If you have to refine a metal, does that mean it isn't naturally occurring? Does steel count as 'unnatural'?
  6. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    Titanium is probably one of if not the hardest metal, there will be dozens of man made alloys that could rival it but I dont know of any off hand.
    Im assuming by natural metals you mean metals listed on the periodic table.
  7. smc8788
    smc8788 Multimodder
    23 Apr 2009
    I've used tools for rock etching before (don't ask) and their tips are usually made of Tungsten carbide.
  8. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
    you spend some thime at shawshank? :D
    and yeah, tungsten carbide or titanium diboride are what you might be after. hardest naturally occuring metal is a tougher one as there are a few different scales, but titanium is less hard than both mild steel and stainless steel (both alloys).
  9. woof82
    woof82 What's a Dremel?
    18 Jul 2005
    Here's a graph of element number against young's modulus, this refers to strength rather than hardness:
    http://www.webelements.com/periodicity/youngs_modulus/
    And here is a graph of hardness against element number:
    http://www.webelements.com/periodicity/hardness_mineral/
    Hardness refers to how much a material resists permanent (plastic) deformation (ie scratching). This is usually measured using mohs or Vicker's hardness. Mohs is simply done by testing which materials can scratch others, vickers involves pressing down on the sample with a known force on an indenter with a specific shape, then measuring the size of the indent (using optical microscopy) and doing some math.
    Note that the hardness and strength of alloys are usually far greater than the pure element. For example iron has a yield strength of <100MPa whereas a high strength low alloy steel can have yield strengths as much as five times greater by only including a few percent of alloying additions and some careful heat treatment
  10. BentAnat
    BentAnat Software Dev
    26 Jun 2008
    Sorry - i Had to.
    pimonserry, Mr Mario and Lorquis like this.
  11. kingred
    kingred Surfacing sucks!
    27 Mar 2008
    Hardness brings fragility, due to its inability to bend and flex with forces required.
    this is why a hardened hi-carbon steel will break given its lack of resistance to shock, hence why tempering is used so it can be made ductile and less rigid.
    Hardness isnt the best thing out there, materials with greater resistance to work hardening and fracture resistance are more desireable.
  12. Domestic_ginger
    Domestic_ginger What's a Dremel?
    16 Mar 2010
    Surely its adamantine. they wouldn't have reinforced wolverines skeleton with it otherwise.
  13. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    What about Diamondium or Diamondillium, :D
    Baz likes this.
  14. Pieface
    Pieface Modder
    8 Mar 2009
    Iron Maiden > Dragonforce.
  15. BentAnat
    26 Jun 2008
    I agree, but /b/ disagrees.
  16. Kalcifer
    Kalcifer If you want change, start with yourself.
    23 Sep 2009
  17. wormy
    wormy Minimodder
    16 Oct 2009
    It just has to be ChuckNorrisium. It's so hard it that it can't be melted or re-shaped.
  18. Veles
    Veles DUR HUR
    18 Nov 2005
    Diamond is the hardest metal known to man
  19. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
    That's Adamantium, not adamantite.
    And Vibranium is stronger than that.
  20. feedayeen
    feedayeen What's a Dremel?
    18 Jun 2008
    Diamonds are made from Carbon, a non-metal.
