News Hardware 25 - What, no Tanks?
Discussion in 'Article Discussion' started by CardJoe, 8 Jul 2011.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    Sweet! Downloading now.
  3. do_it_anyway
    do_it_anyway Minimodder
    24 Apr 2009
    Thanks guys.
    Tomorrows run along the canal will be a little more enjoyable now :)
  4. Xir
    Xir Modder
    26 Apr 2006
    You tested this PPSU in what...2008?
  5. Farfalho
    Farfalho Minimodder
    27 Nov 2009
    Great Podcast.
    I've used for several times the Zalman STG-1, the brushy one, it was cool and very easy to apply but since I was running out of it, i've searched for new and better ones and came across the Arctic Silver 5. MX-2 I've used in my times of pc technician and it was alright. MX-3 just resembles mashed potatoes or even ciment due to its viscosity, just a no no. Have been using the clear film on the finger method because I believe it's the best when not using a proper brush but the video you talked about is quite good to explain to most of us which method is best.
    The video you were talking about is this one, I believe:
    http://www.youtube.com/watch?v=EyXLu1Ms-q4
    Hope it helps everyone.
  6. Xir
    Xir Modder
    26 Apr 2006
    I use the "credit-card" method for spreading a thin even film :D
    Old-fashion razor-blades work very well too just take the one from the heroin kit :D
  7. Combatus
    16 Feb 2009
    Yep that's the one! I think what it shows is that some TIMs such as AS5, do require spreading as they are too thick for this to happen using the mounting pressure alone - personally I've had better results using AS5 spread using the finger method than I have grain of rice + mount pressure method. However, I'm much more in favour of using less viscous TIMs such as MX2 and using the cross method now.
  8. RedFlames
    23 Apr 2009
    i find some thermal goo benefits from being warmed up a little before application... a quick run under the hot tap usually does the trick... makes it easier to spread out...
  9. l3v1ck
    23 Apr 2009
    Is there actually a release date for Bulldozer yet?
  10. Material
    Material Soco Amaretto Lime
    13 Apr 2010
    It's expected in September but AMD wont say anything official.
  11. John_T
    John_T Minimodder
    3 Aug 2009
    Yeah, that was good stuff re: the TIM spreading. I've always (for 10 years plus) scraped a tiny amount over with the film over finger method, then added a (half) grain of rice sized dot in the middle. I'll definitely be switching to the cross method after this.
    I've used Arctic silver 5 for as long as I can remember as well - think I'll have to use one of these MX compounds next time...
    I like learning stuff! :)
  12. pdjblum
    pdjblum What's a Dremel?
    25 Aug 2009
    Though I agree the igp on Sandy Bridge is grossly inferior to the llano solution, I think it is disingenuous to suggest that it was after thought based on it not supporting DirectX11, which you incorrectly suggest is supported by most games.
Tags: Add Tags
