Hardware failure - need clarification
Discussion in 'Tech Support' started by FooLi0, 26 Mar 2009.
  1. FooLi0
    FooLi0 What's a Dremel?
    20 Jul 2005
    Hello bit-tech I'm in need of some aid in diagnosing which part has failed on me, although I'm quite sure it is my CPU I'd like to know for sure before buying a replacement. I have snapped a few photos since i can't take screen caps :duh: so excuse the quality and the dirty monitor :p.
    Oh, also a little bit of info for hindsight I received an error msg for a failed overclock and considering my CPU was the only thing overclocked I'm quite sure it's the problem.
    Anyways here are the pictures...
    Here is the initial boot where it gives me the options for safe mode etc. as you can see many of the characters are distorted.
    Here is the XP loading screen where you can see green dotted lines covering the screen.
    Finally this is XP fully booted and you can't see anything but a black bg and those pesky green dotted lines :wallbash:
    Any insight would be much appreciated
    Thanks in advance
  2. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    Can you post your full system specs?
    Does your motherboard have onboard video or do you have another video card you can try?
    With the artifacting I would suspect the video card.
    How high was the overclock on the cpu?
    Can you remember what other settings were set in the bios? for example was the pci bus locked at 100mhz, was the ram set, what voltage for northbridge, south, just to name a few.
    Try removing everything you can, ie a stick of ram, to a minimum system and see what happens.
  3. FooLi0
    20 Jul 2005
    specs are
    ASUS P5K
    E6600 C2D
    eVGA 8800GTX
    2gb OCZ platinum rev2
    I left the voltage on the cpu as it was and only upped the FSB to reach 3.0ghz. As for the ram It was set to 2.0v.
  4. badders
    badders Neuken in de Keuken
    4 Dec 2007
    Looks like it could be your graphics card.
    Can you try another, or try this one in another PC?
    How long have you had it - check the heatsink's not full of dust.
  5. chrisb2e9
    18 Jun 2007
    I have a p5k and a q6600 at 3.0ghz. did you ever check the temps on the cpu? just wondering if as baders said, was the heatsink full of dust? same question for the video card. check and see if its full of dust. maybe a fan failure as well.
    taking a e6600 to 3.0 with no voltage increase should not kill the cpu.
  6. EnglishLion
    EnglishLion working for the good of mankind...
    2 May 2008
    I have a dead graphics card in my garage that I bought as 'untested' off ebay - it does exactly the same thing. To me this looks a dead cert graphics failure.
    Do you have or can you borrow an alternative to test with? Maybe an independent PC retail outlet will loan you one if you agree to buy a replacement from there later - maybe worth a try!
  7. cpemma
    cpemma Ecky thump
    27 Nov 2001
    chrisb2e9 is right, raising the FSB without locking the PCI bus to 100MHz can unintentionally overclock the video card.. Same for RAM, set to a low ratio before raising the FSB.
  8. FooLi0
    20 Jul 2005
    Well I ended up finding my brothers old GPU and looks like you guys were right it is the graphics card, the most expensive part bah :sigh: :waah: .
