Hardware help please?
Discussion in 'bit-tech Folding Team' started by pompeyrodney, 21 Mar 2015.
  1. pompeyrodney
    pompeyrodney What's a Dremel?
    20 Nov 2009
    Hi all, I have just spent a few hours rebuilding my rig based on an old MSI K9A2 platinum board. It was getting rather hot with two GPUs so I have removed some drives and rerouted the cables to get better air flow. The problem I have is that the OS drive is not being detected. The DVD drive is but not the hard drive. I have tried it on different sata ports and have checked through the bios settings, I know the drive is good as I can browse it in a caddy on a different machine. I have also changed the sata data cable but am now at a loss as to what else I can do? Thanks.:wallbash:
  2. David
    7 Apr 2009
    You checked the HDD priority/boot order in the BIOS?
  3. wilding2004
    wilding2004 What's a Dremel?
    18 Feb 2011
    You said you've tried different sata ports, but have you tried the port that the dvd-drive is using?
    If that doesn't work, try a cmos clear.
  4. pompeyrodney
    20 Nov 2009
    I think I have done that but will give it another go, thanks.
