Windows Hardware Make?
Discussion in 'Software' started by MarkW7, 24 Jan 2009.
  1. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Hello,
    is there a program that tells you;
    the make of your motherboard and specs.
    the make of the ram installed and type, speed.
    Fans installed.
    Anything else usefull.
    thanks!
  2. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    PCWizard 2008 and SiSoft Sandra will both do it, free too.
    It the program appears to freeze, give it time as it is scanning the hardware.
  3. teamtd11
    teamtd11 *Custom User Title*
    31 Aug 2005
    SiSoft Sandra is great, though for me it kills my pc when i try to look at cpu info (just instantly restarts the pc)
    Cpu-z is also great, will tell you motherboard and ram specs.
  4. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    I download SiSoft Sandra Lite 2009 SP2 is that the right one?
  5. mrbungle
    20 Sep 2004
    One i always use is CPUZ as you dont have to have it installed it just runs from its own folder, handy for my repair work as it just keeps on a pen drive.
  6. Akava
    Akava Lurking...
    28 Jul 2007
    +1
    I use it for the same reasons, smaller, simple, and doesn't need installing.
  7. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    +1, also use GPU-Z dose the same as CPU-Z but tells you about the graphics card. Great tool if you dont fancy ripping the case open to find out.
    CPU-Z and speedfan, speedfan requires installing but its light and reports tempertures and fan speeds (only if there connected to a mobo header and the fan has a speed sensing cable.)
  8. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    I second CPU-Z for looking up CPU, memory and motherboard info, but there's no other way than physically checking inside the case to see what fans are installed. :)
  9. MrWillyWonka
    25 Jul 2004
    Whilst CPU-z is indeed very very good the SiSoft Sandra will give you a bit more info such as temperatures.
    Just check all the software out, they are free!
  10. naokaji
    naokaji whatever
    8 Dec 2006
    Cpu-z is great, but the amount of information is limited.
    I'd recommend Everest, far easier to use than Sandra in my opinion.
    link
