Hardwarelabs GTR 360 radiator pressure limit
Discussion in 'Watercooling' started by nikkuzim87, 22 Aug 2020.
  1. nikkuzim87
    nikkuzim87 What's a Dremel?
    22 Aug 2020
    Good morning all,
    I'm just about to start building a loop with hardware labs radiators. Fist time using them and I can't find anywhere that states what pressure they are tested to - for when I do leak testing.
    Can someone who may know - if anyone, let me know please if the Hardwarelabs Nemesis 360 GTR is tested to 1 bar or more?
    Thank you
  2. Big Elf
    23 Apr 2009
    They claim that the Black Ice NEMESIS GTS/GTX radiators are tested to 4.5 bars (65 psi) and can be safely operated at 2.5 bars (36psi) nominal.
  3. Goatee
    Goatee Multimodder
    19 Apr 2015
    I tend to pressure to around half a bar, give all the fittings and tubes a wiggle, then the case a shake. If you leave it for an hour or so then give the case a good shake and fittings and tubes another manipulation. If there is no pressure drop then then your good to fill. Here is my last leak test.
    If you notice a leak during that process, then its normally easy to find. If not then try some washing up liquid on the fittings you suspect. Bubbles indicate a leak.
  4. nikkuzim87
    22 Aug 2020
    Thank you :)
