Modding has any body done a R2D2 case?
Discussion in 'Modding' started by bloddie, 16 Jun 2005.
  1. bloddie
    bloddie What's a Dremel?
    17 Jun 2004
    I was thinking about doing it, but you know if anybody has done it before?
    should I do it?
  2. scifi3018
    scifi3018 Minimodder
    6 Feb 2005
    I have seen somethign like that done before, i dont remeber who it was, but they had servos to control the movement of the head, and leds and mabye some bleep bloop sounds.
  3. IanW
    IanW Grumpy Old Git
    2 Aug 2003
  4. simosaurus
    simosaurus What's a Dremel?
    12 Jun 2005
    that guy kinda cheated imo. He just stuffed parts into a pre-bought r2d2, would have been better if he made it himself :)
  5. Bandit_zoraK
    Bandit_zoraK What's a Dremel?
    29 Nov 2004
    Yeah I made R2s head for my Rogue 5 Project (see my sig) but not the whole thing. It would be cool.
  6. Draeth1
    Draeth1 What's a Dremel?
    5 Jan 2004
    There is one being built from scratch over at GruntvillE, he's just starting out with a 45 gallon plastic drum. But no complete ones built from scratch that I know of.
  7. bloddie
    17 Jun 2004
  8. Pflumingo
    Pflumingo givem the bird.
    17 Jul 2002
    Ok. I will post some pictures later, but I have started (and nearly finished) an R2d2 PC case for my son (it's 2/3 scale) From scratch meaning, using a round 12inch mixing bowl for the dome and sonotube as the body covered in sheet metal.... using the blueprints from the R2 group on Yahoo groups...
    No pics now, but I will probably start posting it in the Projects section soon.
  9. TheGreatSatan
    TheGreatSatan Dark Lord of BT!
    5 Aug 2005
    Did you ever finish?
  10. jaguarking11
    jaguarking11 Peterbilt-strong
    10 Dec 2003
  11. Shuriken
    Shuriken same christmas AV for a whole year
    1 Jan 2003
    If you're gonna make one from scratch I recomend you build the body out of one of those old R2D2 shaped hoovers (vax?) with a metal bowl as the head.
