Electronics has ANYONE ever thought about or tried to build a car amp?
Discussion in 'Modding' started by BobbyMParr, 4 Feb 2006.
  1. BobbyMParr
    BobbyMParr GameDemon
    18 Jun 2004
    Ok so it was just an idea has anyone ever thought about or attempted to build a car amp.? for a sub ?
  2. ConKbot of Doom
    ConKbot of Doom What's a Dremel?
    2 Jul 2003
    Homemade amps really aren't the hard part, its getting the voltage to power the amp is the problem. 12v into 2 ohms is 6 amps. 6 amps * 12 v is 72W, so the most you could get from 12v, above that and you need a DC-DC converter/SMPS. Not easy things to build.
  3. cpemma
    cpemma Ecky thump
    27 Nov 2001
    And that's Peak Power with no transistor losses. Typical car radio amps go to about 25W RMS max with the engine running. TDA2005 and TDA7240 ICs make easy car amps, but only 20W RMS claimed.
  4. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    the easies soultion would be to take the electronics from a 12-230V inverter and make a basic amp after that. it will probably need some noise filtering, tough.
    Switch mode PSU's aren't the easiest thing to work with.
  5. BobbyMParr
    18 Jun 2004
    anyone have a diagram or something like that?
    and a list of parts?
  6. Static Lullaby
    Static Lullaby What's a Dremel?
    1 Feb 2006
    If you go to www.caraudio.com they have a forum there I have been a part of for quite a while. A number of folks there have built their own car audio amps. Most are not very powerful and some have become rather costly projects. If you can manage to get ahold of a guy by the name of JLaine he would probably be one of the best to help you with that particular project. (his knowledge in the field is untouched by many)
  7. BobbyMParr
    18 Jun 2004
  8. Xiachunyi
    Xiachunyi What's a Dremel?
    3 Nov 2003
    Maybe this site will help you.
    For power, I guess you could go with an inverter.
  9. Static Lullaby
    1 Feb 2006
    To build an amp comparable to that... will take a good deal of $ as well as be pretty massive. It would probably honestly be easier to buy an amp and mod the exterior of it, if you are looking for something to be custom.
  10. Wolfe
    Wolfe What's a Dremel?
    7 Sep 2003
    To put it simply, if you don't know enough to need to ask, you don't have the skills to build a car amp. They're really complex.
    I wouldn't try it.
  11. BobbyMParr
    18 Jun 2004
    awnser me this static would it be ANY cheaper building my own even if its only $15 bux
  12. Wolfe
    7 Sep 2003
    No, it would likely wind up costing more, actually.
