Case Mod - In Progress Hask. Liquid cooling. 22 Aug mini update.
Discussion in 'Project Logs' started by Hask, 5 Jul 2012.
  1. Hask
    Hask What's a Dremel?
    5 Jul 2012
    Hello everyone.
    This is my second mod. It will be with a liquid cooling. About 5-6 months ago, I ordered the parts from China. But because of the study, only now I had time to implement my project.
    My case is Aerocool Vs-4.
    My project (it is toggle switches over DVD-rom).
    LC parts:
    In future i will remake top of wb.
    Chinese sent a wrong reservoir - 35x6cm instead of 20x6. :duh: So i had to redo the project.
    Disassemble the case and cut a hole for the reservoir.
  2. Hask
    5 Jul 2012
    Decided to invest in a small upgrade. Now I have Z68 Ex4 Gen3 + i5 2500k + 2x4Gb 2133MHz Kingston.
    Now i have to redo mount of the CPU water block.
    I finished to cut case:
    Cut new holes for the tubes on the rear panel. Older will be covered later.
    Сombined top holes for the 24 pin wire.
    The computer from which I write now :D
  3. dan-mel
    dan-mel What's a Dremel?
    10 Jul 2012
    Looking good, the external radiator should look sweet.
    Love the current computer too :hehe:
  4. GamerIDGoesHere
    GamerIDGoesHere www.^.com
    3 May 2012
    Looks like it has some potential! Keep up the good work.
  5. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    what the GPU block is? i'm making something very similar...
  6. Hask
    5 Jul 2012
    Not sure what I understand the question, but I did not do GPU block, I bought it from the Chinese. It is made ​​of copper.
  7. Cheapskate
    13 May 2007
    I like the reservoir. Where did you order from? It looks like a design I made that didn't get OK'd.
  8. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    ^^^LOL. The GPU block looks like an Alphacool and so does the CPU block. Ive never seen the res before.
    Nice cuts with the Dremel, or are you showing us pics AFTER massive filing?
    Either way, nice looking so far, and that UV CCFL on the res looks sweet too :)
  9. Hask
    5 Jul 2012
    Thanks for comments.
    I ordered on the Taobao two such, but they sent two like this.
    By the way they are really cheap (80 yuan ~ 12.5$.), but the delivery is only through the intermediary.
    It's after filling with sanding paper.
  10. bluc
    bluc What's a Dremel?
    4 Apr 2012
    Nice work :thumb:
  11. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Shaping up to be nice project, Hask. Great photos!
    Your creations are under Surveillance cheaps :worried:
  12. Hask
    5 Jul 2012
    Began to make the panel with the switches and diodes. Housing made ​​from 2mm plastic and covered with vinyl tape.
    Coolers painted fluorescent dye. One 120mm and three 40mm.
    Check the sizes for the laser cutting.
  13. Hask
    5 Jul 2012
    Remade mount for WB. I'll dye and cut screws later.
    Cooling for the memory.
    It's all done with laser cutting
  14. zero_be
    zero_be What's a Dremel?
    22 Aug 2012
    Can you please provide us with the schematic for the fan controller? Keep the good work!! :thumb:
  15. Fuganater
    Fuganater What's a Dremel?
    6 Jul 2011
    Awesome build. + sub
  16. Evenge
    Evenge Minimodder
    16 Sep 2006
    Good work! :thumb:
