Watercooling Have I made a good decision?
Discussion in 'Hardware' started by LukeDaly, 9 Oct 2011.
  1. LukeDaly
    LukeDaly Pokemon Master
    9 Jun 2011
    EK Water Blocks EK-Supreme HF - Acetal+EN Nickel 775/ 1156/ 1366/ AM2/ AM3
    EK Waterblocks EK-FC6970 Acetal V2 + Nickel x2
    EK Water Blocks EK-CoolStream RAD XT 360
    EK Water Blocks EK-CoolStream RAD XT 120
    16/10mm Compression Fitting Straight G1/4" Black Nickel Plated (ID 3/8" OD 5/8") x8
    Arctic Silver 5 - 3.5g x2
    12V Alphacool Laing D5 Vario Pump VPP655 SINGLE
    EK Multioption RES X2 - 150 Advanced
    EK Water Blocks EK-D5 X-TOP - Acetal G1/4 Rev. 2
    Phobya Nano-2G 12 PWM Silent 1500rpm Red LED Double Blade (4-Pack)
    Phobya Nano-2G 12 PWM Silent 1500rpm Red LED Double Blade (120x25mm)
    16/10mm Compression Fitting 45° Rotary G1/4 - Knurled - Black Nickel
    16/10mm L Compact Compression Fitting - Black Nickel
    Anti Vibration Damper Pad - Noise Destructor V1.1
    Reccommended red tubing?
    what do you guys think?
    £562.38 is alot of money to spend on water cooling?
    Or would I be better just using water on the cpu and getting 2 Asus Direct CuII cards?
  2. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    Have you tried second hand stuff yet... and do you need compression fittings, Im not sure as Ive never WCed.
  3. LukeDaly
    9 Jun 2011
    yehh man thought about it, although im always abit cautious on second hand goods, and they just make life alot easier
  4. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    I'd drop the 120mm rad, as it'll do nothing extra ontop of the 360.
    The marketplace is good for fittings, tubing ect, but I'd avoid rads as I had a leaky one before. Otherwise, that's the cost of WC these days, I've noticed prices have been rising over the last couple of months.
    As for red tubing I've used the masterteer stuff and its nice and red in normal light but more orange in UV...
  5. LukeDaly
    9 Jun 2011
    really? surely the 120rad lets out more heat?
  6. Bloody_Pete
    11 Aug 2008
    TBH onto of that 360 it'll only be a couple of degrees so it wont do alot. price vs performance it's not worth it...
  7. LukeDaly
    9 Jun 2011
    ok thanks man, also do all them parts work together and stuff?
    first waterbuild noob here.
  8. bulldogjeff
    2 Mar 2010
    I would use the 120 rad to cool the CPU so the loop would look like this...Res>Pump> CPU> 120> GPU's> 360>Res...Why RES X 2? If you're planning 2 loops you'll need 2 pumps, other wise for a single loop 1 res will be all thats needed.
  9. Bloody_Pete
    11 Aug 2008
    Wont you need 10 compression fittings?
  10. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    Asus Direct CuII cards run very cool. I have the GTX580 and compared to my old 470 there's a difference of 40deg
