Build Advice Have i missed anything??
Discussion in 'Hardware' started by chrispy61, 13 Sep 2010.
  1. chrispy61
    chrispy61 What's a Dremel?
    29 Jan 2010
    So far ive bought, ready to be built......
    Case
    Mobo
    Ram
    CPU
    PSU
    Windows 7
    Hardrive
    Optical Drive
    CPU Cooler
    Mouse
    Keyboard.
    What else to i need? Neva built one b4 so getting prepared for my week off when im gunna build it.
  2. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Graphics card? Or are you using a motherboard with integrated graphics?
    Also, do you already have a monitor for the build?
  3. roosauce
    roosauce Looking for xmas projects??
    12 Feb 2010
    Have you bought everything new? If not, there will be some cables that you might need.
    Also have a think about tools that you will want to use. A couple of magnetic phillips head screwdrivers are generally needed (look for a number 2). Needle-nosed pliers, a small flashlight/torch, small wire snips ...
    You can buy small kits pretty cheaply if you don't have any of these items.
  4. aLtikal
    aLtikal 1338-One step infront of the pro's
    7 May 2008
    Anti static wristband....or just touch something that is earthed like a radiator (make sure its an unpainted part) every 15mins.
    Ive done this with the 8 PCs I've built and never had a problem.
  5. chrispy61
    29 Jan 2010
    Having to buy new monitor, but still undecided on that. And same with graphics card probly Geforce 210.
    What about cable management, case fans?
  6. roosauce
    12 Feb 2010
    If you bought the case new then it should have a basic acceptable number of fans. Many cases have cable routing holes, but some cable ties are still helpful if you dont have them.
    I would need to know which case you have bought to help you further on these points.
  7. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    What exactly are you going to use this computer for? Surely not gaming.
  8. chrispy61
    29 Jan 2010
    Antec 300 on that one.
    No, general computing and music production.
    What about thermal paste?
  9. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Feel free to pick up some arctic silver but your CPU cooler should come bundled with some decent paste.
  10. chrispy61
    29 Jan 2010
    Cable braid?
  11. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Entirely cosmetic.
  12. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    With an Antec 300 you will need some cable ties as mentioned above, it will make life much easier getting the cables out of the airflow inside the case.
    Do you know how many SATA cables you get with your motherboard? Make sure it is enough for your hard drive(s) and DVD.
  13. chrispy61
    29 Jan 2010
    Thanks for the heads up
