Windows Having problems installing windows (Problem Solved)
Discussion in 'Software' started by Drastik, 9 Oct 2005.
  1. Drastik
    Drastik What's a Dremel?
    10 Jan 2002
    I recently traded my laptop for a dual Xenon 2.4ghz server. NOw my problem is i cant get windows to install. Ive treid winxp home winxp pro and win200. Only version that works is win server 2003. Can somone help me as i really want xp pro
  2. DivineSin
    DivineSin What's a Dremel?
    23 Apr 2004
    What happens when you try to install the other OS's?
  3. Drastik
    10 Jan 2002
    it format then install, retsrts and when it goes to configure it gives an error about something cant be configured. ic ant remeber exaclty what it is
  4. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    It could be because WS2k3 is designed for dual or quadrouple processors, so it might be that non-server versions do not support it, check out the MS website.
  5. Drastik
    10 Jan 2002
    well i was looking at the compatability chart on the mother board wesbite and it says it supports xp pro but i cant get it to work...do i have to have sp1 or sp2 streamlined into my install disc
  6. MrWillyWonka
    25 Jul 2004
    That is another possibility. What you can do is download nlite, which is a program where you can customise windows, using your existing copy on windows. There is a feature to add service packs to the disk. (You'll have to burn an ISO of the customised XP)
  7. Drastik
    10 Jan 2002
    soo you are saying download sp2 and streamline it into my xp pro cd
  8. alcedes
    alcedes What's a Dremel?
    1 Jan 2005
    It would be very helpful if you could get the exact text of the error message.
  9. MrWillyWonka
    25 Jul 2004
    Yes, its worth a try.
  10. Drastik
    10 Jan 2002
    ill try to slipstream but if that doesnt work ill tell you the exact error msg
  11. Drastik
    10 Jan 2002
    ok i tried using nlite to slipsteam the drivers and sp2 but after it installs then reboots to configure everything with the gui well i get the a blue screen before can configure and it says unmountable boot device. what is that
  12. kenco_uk
    28 Nov 2003
    I've had recent issues with installing win2k on a fairly old-ish computer. It would install and run for a bit, then give a permanent innaccessible_boot_device blue screen on loading up. If I then ran a scandisk using the win2k cd recovery console, it always brought up three errors that were fixed (what they were, I've no idea). After a few hours-worth of trying to figure it out, I ghosted the install onto another hdd and it appears to be fine. Even though SMART was enabled for the drive in bios and it reported the drive as ok, it would seem that it wasn't. So, it may be worth trying to install on a different hdd.
  13. Drastik
    10 Jan 2002
    ok here is the exact error
    UNMOUNTABLE_BOOT_VOLUME
    blah blah blah if ytou installed new hardware blah blah blah
    ***STOP: 0X000000ED (0C86373C08, 0XC000185, 0X00000000, 0X00000000)
    I have treid a diff hdd and it does the same..funny thign is win2003 server works fine but thats not what i want
  14. kiljoi
    kiljoi I *am* a computer king.
    13 Oct 2003
    What type of drives are they? IDE, SATA, SCSI? Also, are you trying to install to a RAID setup?
  15. Drastik
    10 Jan 2002
    ide drives and no raid
  16. Drastik
    10 Jan 2002
    any ideas
  17. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    The ide channel doesn't need drivers loaded? you know when it says to install a device from floppy press f6 or words to that effect. Is it on a funky chipset as apposed to just being part of the south bridge?
  18. padrejones2001
    padrejones2001 Puppy Love
    17 Jun 2004
    You only need to install drivers if you have a RAID controller. My guess is that something is wrong with the actual operating system that you're installing, because I know that XP Pro supports dual processor configurations.
  19. Comg33k
    Comg33k What's a Dremel?
    12 Jul 2005
    Adding to the last post, you can get your xp pro disc cleaned professionally. CompUSA does provide this service and they do a mighty good job at it.
    I had a totally messed up Christmas CD that couldn't play any of the tracks on any audio player and had it professionally cleaned from CompUSA and it's good as new. It's cheap and you get like 20 cd's done for like $20 bucks, $1 for each cd.
  20. Drastik
    10 Jan 2002
    no my cd is good it will install on my other machine
