Having problems running FaH CPU
Discussion in 'bit-tech Folding Team' started by JohnSheridan, 4 Jan 2011.
  1. JohnSheridan
    JohnSheridan What's a Dremel?
    30 Dec 2010
    OK tried this so many times about to give up on it.
    Running FaH GPU client fine on my nVidia graphics card but thought I would try the SMP2 for my i7 950.
    Finally got it installed and setup using old dos type command so advanced flag is set to -smp and it said setup was ok and has downloaded a work unit - Project 6883 however my cpu useage is only showing 12% and 1% has taken 4mins so far. :waah:
    How can I get this to use the other 88% cpu which is just idle?
  2. jondi_hanluc
    jondi_hanluc Retired Folder
    15 Oct 2010
    http://foldingforum.org/viewtopic.php?f=24&t=17132
    "project 6883: 69 points"
    Looks like upon set up you didn't choose "big" packets which are multi core, default is normal which only uses one core. Close the smp client, delete your work folder, add the -advmethods flag, as well as -smp, then restart the smp client again, see how that goes.
  3. JohnSheridan
    30 Dec 2010
    Strange as I've checked again and "big" was selected.
    Anyway have deleted the work packet and added the -advmethods flag along with the -smp flag and it is now showing as cpu running at 100% and on Project 6061 although that is down as only worth 481 points :sigh:
  4. jondi_hanluc
    15 Oct 2010
    481 points is the value without the bonus points, are you using Fahmon? I don't think that calculates the bonus points, or at least it didn't used too, HFM calculates them.
    In case you don't know to get the bonus points you need to get a passkey from stanford, and enter it into your client, then after you've completed 10+ WU you'll get the bonus points.
  5. StreetSam
    StreetSam Minimodder
    30 Aug 2005
    That is correct, 6061 is a standard A3 WU, with a 950 that should give ~9000+PPD. if you are trying to get BigAdv WUs then you need to add the -bigadv flag (and be running an overclock, probably). Then when you have folded 10 WUs you will get the bonus.
  6. saspro
    saspro IT monkey
    23 Apr 2009
    Hi John.
    Get a passkey from Stanford and keep crunching the SMP's after 10 you'll notice a massive increase in points
  7. JohnSheridan
    30 Dec 2010
    Thanks for your help - have now requested and got a passkey from Stamford so onwards and upwards!
    When my i7 970 arrives I assume I could get that to look at the BigAdv units or just leave it "as is" (set to Big) ?
  8. BennieboyUK
    BennieboyUK CPC Folder of the Month Sep 2011
    24 Nov 2010
    Welcome to the forums John, I would get your 10 WU's done, see how it all performs and then have a tinker with the BigAdv after that.
  9. JohnSheridan
    30 Dec 2010
    Just popped this on to another computer - running i5 2500 processor.
    Running but only 25% of cpu.
    What have I missed?
  10. DocJonz
    DocJonz Another CPC refugee .....
    24 Apr 2009
    Probably the "-smp" flag - Without it you run the single client on one core.
