Watercooling having trouble finding large radiators /heater core
Discussion in 'Hardware' started by rayson, 16 Jun 2011.
  1. rayson
    rayson Damn sure it was legal
    23 Jul 2010
    i'm planing on a water cooling scratch build which is in design stages. i'm looking for rads or heater cores which could take fans of 200mm or large, i prefer the heater cores since i could cut it up and things like that. also i just want to put one of these fan 200mm +fans as they are for an sfx build also i woulf prefer if the rads/cores were not of folded fin design
  2. rayson
    23 Jul 2010
    something like this
  3. rayson
    23 Jul 2010
    thing is that this is a bit too large a expensive, i don't mind if the radiators come from car parts
  4. bulldogjeff
    2 Mar 2010
  5. Big Elf
    23 Apr 2009
    Car radiators or heater cores should be cheap enough from a scrappy but the vast majority are aluminium so would need anti-corrosion additives to help prevent galvanic corrosion if you also have copper in the loop. I've seen copper truck rads but they were around £200. The other problem would be that 200mm fans have very little static pressure so won't be very effective however a lot depends on your potential heatload.
  6. rayson
    23 Jul 2010
    i'm looking for car heater cores but don't know where to look for them, i don't think we have a local scrappy
  7. rayson
    23 Jul 2010
  8. rayson
    23 Jul 2010
  9. Big Elf
    23 Apr 2009
  10. rayson
    23 Jul 2010
    i think bit fenix uses the same oem as the antec for their fans but theirs hgave a slightly different blade design
  11. rayson
    23 Jul 2010
    looks like the mk1 golf heater core is perfect thanks only 20 quid as opposed to the 50 and 80 pound alternatives
  12. Big Elf
    23 Apr 2009
    Double check how the ports connect. You need to be able to connect your tubing to the ports and possibly braze/solder reducers onto it if they're needed.
