News Haxx teases passively-cooled ATX midi-tower
Discussion in 'Article Discussion' started by Gareth Halfacree, 8 Jul 2013.
  1. Gareth Halfacree
    4 Dec 2007
  2. Stanley Tweedle
    Stanley Tweedle NO VR NO PLAY
    3 Apr 2013
    I think they should have shown a photo of the finished design.
    80w? Yeah... ok. I will make sure I don't overclock much then.
  3. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    I get the impression the pictures are the finished design.
  4. Stanley Tweedle
    3 Apr 2013
    I think it's like an EA game... Didn't have time to finish it but they released it anyway hoping no one would notice.
  5. kirk46
    kirk46 Cheesecake Nom Nom
    9 Jun 2012
    how much :eek:
  6. Dave Lister
    Dave Lister Minimodder
    1 Sep 2009
    If it can cool passively then adding a few fans should have great results. I'd love to see a review of this BT !
  7. schmidtbag
    schmidtbag What's a Dremel?
    30 Jul 2010
    Not necessarily. The reason for it's design is so ambient air coming from any direction will help cool off the system. Putting a fan in there would obviously cool things off better but it'd be less effective than standard towers (that are laid out properly), where you want to have a constant path of air flow. Having a good heatsink and tower with good air flow *can* make the difference between needing to water cool your CPU and not. Having holes everywhere like this tower disrupts good air flow.
    Personally, I think getting a plain motherboard tray with a car radiator might be a more effective option than this tower.
  8. Dave Lister
    1 Sep 2009
    I lol'd, a car radiator is definitely cheap enough to get hold of ! I think the fans on most of them should be 12v too ! A great idea for a future mod I reckon, cheers man ;)
  9. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    I've been toying with this idea for a while, so it's good to see someone try it. Do they say anything about how they're going to get the heat from the CPU to the case? Some sort of heat pipe arrangement?
  10. Corky42
    30 Oct 2012
    Thermalright had a heatsink case on show during computex 2007, but im guessing it never made it past the prototype stage :miffed:
  11. tad2008
    tad2008 What's a Dremel?
    6 Nov 2008
    It's already been done, I saw an episode of dl.tv where they hooked up a standard water block to the cpu and then converted the pipes to fit a car radiator and fan and it cooled the same as it's smaller and by far quieter pc component brethren :D
  12. schmidtbag
    30 Jul 2010
    lol gee, I wonder why. I'm sure that's ridiculously expensive and heavy.
