Scratch Build – In Progress HCC - Hybrid Concept Case [DJB] (finished) final pictures and concept explanation
Discussion in 'Project Logs' started by Diegojavbau, 6 Aug 2011.
  1. teo331
    teo331 What's a Dremel?
    21 Aug 2011
    That's a really nice case! Just one question, i intead to make a case (with a mini-itx due to small space) and i noticed that you connected the aluminium parts with some kind of screw which can't be removed. I have seen the same method in many other commercial cases and i whould really like to learn how they are called, how to you place them and in what kind of shop i can find them.
  2. Diegojavbau
    Diegojavbau What's a Dremel?
    13 Jul 2011
    Temperature ? I will know when I finish xD
    There is so many fans , temperatures will be fine
  3. sparkyboy22
    sparkyboy22 Web Tinkerer
    3 May 2010
    I dont yet understand how this will all fit together.
    Looking forward to the penny dropping.
  4. Cheapskate
    13 May 2007
    DUDE! If you don't cover the rig with the tablecloth material, I will die and haunt you!:D
    -Sorry. I'm just saying that that black cloth would look good on a case.:thumb:
  5. Diegojavbau
    13 Jul 2011
    Update
    The model was open like an easter egg , to work on it and to put the aluminium chasis inside.
    Some pictures of the cuts fot the hardware .
    Mothertray window
    Optical drives and HDD Rack
    Wide view
    Fan holes
    Other point od view to show the hole for the PSU fan
    Acordin to the concept of the One-unit of the mod , I will not use grills , I will made it in the main body of the mod
    Front grill
    Draw of the otical drives holes
    Grill on top done
    Front holes and grills done
    PSU window + I/O panel + expansion card
    I will made a toolless-like system to fix in position the optical drives , front panel and HDD Rack , holes for that
    Frontal image
    Holes for the cable management , very important to the functionality of the mod
    Now is time to close the coffin again , but with the aluminium chasis inside
    The gap that remains is because the measures was for fiberglass , not for 3mm MDF , let's work on it
    Some accesories and acrylic side panel
    Next the final pictures :rock: :rock:
  6. Diegojavbau
    13 Jul 2011
    The main concept of this project was made a scratch build mod with all the basics of modding (big side window , front and bottom blowhole , rear and top fan's extracting hot air) , but introducing a new concept of build and functionality (new at least for me)
    This case is a concept prototype of hibrid chassis , made of aluminium and fiberglass (aluminium and MDF in this beta version) , where there is just one modular unit , the only removable piece is the acrylic side panel and 2 fan covers (no front cover , no top cover , no side panels)
    The main challenge with this proyect was the planificacion to make this functionality work , for that I include extractable pieces (HDD rack , mothertray , front control panel) , and a routing system for the cable management to make it reach all the case
    This is the 3d-render that I made as a model in the beginning
    Here the final pictures of the job done , I hope you like it
    PD : I notice that the reaf fan is in the wrong position after the photo session , :( , I already turn it to the rigth position
    Marcos_Viegas likes this.
  7. LazyMan
    LazyMan What's a Dremel?
    9 May 2010
    Very nice bro.....
  8. LeandroJVarini
    LeandroJVarini Mod is my life!
    25 Dec 2007
    nice!!!!!!!!!!!
    congrats
  9. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    very nice and different solution =)
  10. Diegojavbau
    13 Jul 2011
    Thanks !!!!! =D
  11. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    *Cough* paint the dvd drive *cough*
    Besides that it's a very nice case! I could never do that! :thumb:
  12. Diegojavbau
    13 Jul 2011
