Graphics HD 4850 512 MB DDR3 256-bit Toxic Edition VS HD4850 1024 MB DD3 256-bit
Discussion in 'Hardware' started by dorin, 28 May 2009.
  1. dorin
    dorin What's a Dremel?
    28 May 2009
    I have to do a choice.
    This are my options :
    Sapphire Ati Radeon HD4850 Toxic 512MB GDDR3 256bit, HDTV, Dual DVI/TV-Out, PCI-E
    (it comes pre-overclocked )
    or
    HIS ATI Radeon HD 4850, 1024MB, DDR3, 256biti, PCI-E
    or
    Sapphire ATI Radeon HD4850 VAPOR-X, 1024MB DDR3 256bit, PCI-E.
    Thank you in advance for your replies.
    Kind regards.
  2. Paradigm Shifter
    10 May 2006
    Depends what sort of resolution you're running. If it's fairly low (1440x900 or lower) I'd say go with the 512MB one if it's cheapest. If you're running a higher res (1680x1050 or higher) then go with one of the 1GB cards.
    If the Vapor-X cooler on the Sapphire board is as good as the previous Vapor-X coolers, it'll be good. I'd probably go with that one.
    Price is a factor, though, too - a few of the 4850 cards cost more than 1GB 4870's, which are faster...
  3. dorin
    28 May 2009
    At the moment 1440/900 resolution . I was thinking about 4850 Toxic Edition , because in many internet reviews i saw good conclusions about it. But my problem wich its really bothering me is about 512mb or 1024mb version :)). Price differences are off the point. 512 version is a good choice for now , but , probably in the future a 1024 one would be nice as long everything is faster going up today in games industry.
  4. azrael-
    azrael- I'm special...
    18 May 2008
    Of the three I'd definitely go with the Vapor-X model. Also, you might want to have a look at a Geforce GTX 260, especially from Gainward/Palit. Price should be much the same, but you might get a bit more oomph from it.
    pimonserry likes this.
  5. hotnikkelz
    hotnikkelz What's a Dremel?
    28 May 2009
    I don't think you should buy a 4850 at all personally, from what i gather HD 4770 would be superior in value.
  6. Paradigm Shifter
    10 May 2006
    Aye.
    Really, gaming at 1440x900, a 4770 will do great. :) And at about £80, it's likely cheaper than those others.
    Are you planning on upgrading your screen any time soon? Or are you happy with 1440x900?
  7. dorin
    28 May 2009
    Yeah, I have been thinking recently about 1680x1050 one .
  8. hotnikkelz
    28 May 2009
    hmm, what's your motherboard?
  9. dorin
    28 May 2009
  10. Paradigm Shifter
    10 May 2006
    If you're going to upgrade to a higher res screen - particularly if you might want to turn anti-aliasing on or run HD texture pack mods in games - shoot for one of the 1GB 4850's. :) I've got a Gigabyte-brand one that did very well at higher resolutions and AA levels even when paired with a less-than-amazing CPU. :)
    Still, dependent on the prices of those 1GB 4850's, it might be worth a look at a 1GB 4870. Depends whether cost/performance or cost/quiet/cool are priorities. Even so, no card out of 4770, 4850 or 4870 is going to be a slouch. :)
  11. Elton
    23 Jan 2009
    I want to recommend the GTS 250, if only because it's the same price and performs generally better.
    Or just get a Re-certified GTX260(US/Canada only).
  12. hotnikkelz
    28 May 2009
    Yeah i agree with Elton, you might wanna lean to the gtx 260 core 216.
    Either that or go with shifter's recommendation of 4870 1gig.
    The argument still holds to not bother with the 4850 though.
  13. dorin
    28 May 2009
    Thank you for replies.
    One more question :
    Wich one between AMD Phenom 8650 Triple-core, socket AM2+ / AMD Athlon64 X2 7850 Dual Core, 2800MHz, Socket AM2+, Black Edition.
    Or something in 100 $ range.
  14. Paradigm Shifter
    10 May 2006
    I'd probably go with the triple core CPU.
