Graphics HD 7950 reference card
Discussion in 'Hardware' started by littlejames, 27 Dec 2012.
  1. littlejames
    littlejames What's a Dremel?
    5 Nov 2012
    Does anyone know of any HD7950 GFX cards that are reference design?
    I cant seem to find any! Is there an online database that has a list of reference cards?
    Thanks for your help.
  2. rollo
    rollo Modder
    16 May 2008
    Why? There is very few if any left as they are very loud and very power hungry. You can get quieter overclocked custom cooled models for less money than a reference card sells for on scan.
  3. law99
    law99 Custom User Title
    24 Sep 2009
  4. littlejames
    5 Nov 2012
    So that I can w/c it.
    Thanks for the links.
    I didnt realise that you can reverse search on the EK cooling config site.
    Just search for the specific waterblocks & they will list all of the cards which it fits!
    I was doing it the other way around - searching for the GPU to see if it fits.
