Electronics HD activity LED - How much current ?
Discussion in 'Modding' started by scimmy, 18 May 2005.
  1. scimmy
    scimmy Minimodder
    17 May 2005
    l'm in the throws of modding my machine and would like to
    increase the size of the LED. lt's currently (Ooops) got a
    yellow 3mm beast but l'd like to go for a 5mm one or
    possibly 2. Can you give me an idea of what sort of current
    might be available without resorting to any form of relay
    switching please.
    The mobo is an ECS P4S5A
    Many thanks
    Andy
  2. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    An Opto-isolator is better then a relay in this case.
    :search:
    THe current used from the LEDs is dumped directly into your harddrives.
    I would not put more then 90mA on that line.
  3. scimmy
    scimmy Minimodder
    17 May 2005
    Ok, thankyou. l'll stick with the one 5mm yellow for the time being.
    Many thanks
    Andy
  4. Ghlargh
    Ghlargh What's a Dremel?
    16 Nov 2003
    The HDD LED connector on the motherboard is usually a 5V signal with a resistor for a 2V 20mA LED, meaning it can drive LEDs with a higher voltage, but they will get slightly less than 20mA
  5. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Actually you can put any led you like in place of the existing one, even a dozen Luxeon Stars in parallel, the onboard resistor will limit the current to a safe value (and your Luxeons will be a bit dim ;)). But if you want to set the brightness, use the optoisolator circuit. :cooldude:
    But if you decided to swap or bypass that on-board resistor, I'd not go over 15mA as it's probably a logic chip doing the switching. Normal HDD activity leds run at under 10mA, whatever their nominal rating.
