HD / MoBo Compatability Help?
Discussion in 'Hardware' started by D-an-W, 5 Dec 2006.
  1. D-an-W
    D-an-W What's a Dremel?
    9 Nov 2002
    Hi folks, is anyone using the following HD and MoBo Combo please that has bought the drives recently? "Maxtor 6H500F0 500GB SATA300 7200rpm 16mb Cache Hard Drive" & "ASUS P5N32-SLi SE Deluxe" or any MoBo with the NForce4 RAID Chipset?
    I read conflicting reports on the compatability of the two and wanted to be sure they are going to work before coughing up almost £300 on two new HD's :confused:
    TIA...D-an-W
  2. Krikkit
    21 Jan 2003
    NF4 chipset should be able to cope with nearly any HD size. They'll be fine tbh. :thumb:
  3. D-an-W
    9 Nov 2002
    Thanks for the fast response...
    Just come across This and This On my travels, surely they must have fixed it by now :duh:
  4. Krikkit
    21 Jan 2003
    I'd suggest you try it to be honest. Sounds like a mixed bag, and there's always a patch for it if you get data corruption etc. :)
  5. D-an-W
    9 Nov 2002
    Ordered... :clap:
