Hd Problem
Discussion in 'Hardware' started by BruceLee333, 11 Jun 2002.
  1. BruceLee333
    BruceLee333 What's a Dremel?
    20 May 2002
    I recently bought hd
    Western digital
    80Gb
    8Mb cache
    7200rpm
    and i tried installing it in my pc, there seems to be nothing wrong; i.e. all the wiresa are in and connected and the power is in but when i go to bios and check for the drive which is set to slave and my other 9.5 to master. It detects the master but not the new one, if anyone know the answer to this porblem please tell!:cries:
  2. jamiesurfs
    jamiesurfs Boom Boom, Cha Cha Cha!
    21 Oct 2001
    I have a problem with one of my drives that although the power is attatched it does not connect properly and I have to play with the wire a little. Try that.
    If not, try different combinations of master and slave or a different IDE cable.
  3. BruceLee333
    20 May 2002
    which wires? and i have tried 2 different ide cables
    thanks:lol:
  4. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    try putting the new hdd on its own cable and see what comes up then...
    also what is the jumper configuration on the back of the new one set to??
  5. BruceLee333
    20 May 2002
    new one is set to slave and the old one with windows xp on is master.
  6. jamiesurfs
    21 Oct 2001
    All of them, but particularly the molex wires. Just recheck anything that could be loose!
    Also, have you tried changing which connector on the IDE cable goes to which drive?
  7. felix the cat
    11 Jan 2002
    y not run the new one as master....bound to be much faster....
  8. BruceLee333
    20 May 2002
    if your saying put the new one as master and the old one as slave then, i thought you would need to install xp on there first
    but the problem is when the computer attempts to detect it .......it just stays on auto detecting for a long time and i tried it a couple of times
  9. jamiesurfs
    21 Oct 2001
    In your bios you can change the boot sequence, and ask it to look for other boot devices. No harm in trying!
  10. felix the cat
    11 Jan 2002
    so u reckon the new one is dead??
    have u tried puttin it on there all on its own?? ie nothing else attached to teh same ribbon cable??
    try that....also what mobo have u got??
  11. BruceLee333
    20 May 2002
    give me a sec i have to reboot to check and i had this comp since 1999 so its old does that have anything to do with it???
    gimme a couple of minutes
  12. felix the cat
    11 Jan 2002
    nope, but it would help to know what mobo you have...
  13. BruceLee333
    20 May 2002
    well the infoemation i found was
    AOPEN
    AX6BC
    R.2.20
    BIOS V4.60PGMA
    01/19/1999-1440BX-00000006C-OO
    IN NO PARTICULAR ORDER JUST INFO OF THE SCRREN THAT MAY BE USEFUL
  14. felix the cat
    11 Jan 2002
    so what happens if you put it on its own cable??
  15. felix the cat
    11 Jan 2002
    that is quite old, so im not 100% certain the hdd is compatible...but have u tried the hdd in another pc btw??
  16. BruceLee333
    20 May 2002
    no its the only pc ive got YET, but are there any bios upgrades i can use :worried:
  17. GunDam
    GunDam Minimodder
    9 Feb 2002
    Ah old mobo and old BIOS.
    Its sounds more likely that the BIOS doesnt recognise the new 80Gig hdd size (80Gig hdd are relatively new tech), i think 30gig was the max back in '99 ..... as the guys have said, try flashing the BIOS, the mobo should see it then.
    Additionally .... I would recomend you set the 80gig as a master and on its own IDE channel if u can, so u dont bottleneck that speedy beast!
  18. felix the cat
    11 Jan 2002
    theres about 6 different versions of your mobo so i need more info to be able to identify it properly....
  19. ug_the_caveman
    ug_the_caveman What's a Dremel?
    31 Mar 2002
    Can't go wrong with that, and are you sure the jumpers are set? Might just be little things, such as cables not in properly or something. Or it may be the old mobo / bios or a combo of these things.
    Ug :D
  20. BruceLee333
    20 May 2002
    well i had a lok through for some info and heres wat i came up with:
    CPU: Intel Pentium III / Intel Pentium II / Intel Celeron Slot1 CPU Table
    ASIC: Intel 440BX AGPset
    Architecture: 2 ISA slots + 5 PCI slots + 1AGP slots
    Max. Main Memory : 768 MB SDRAM or Registered SDRAM for DIMM X 3
    DIMM Type: 8/16/32/64/128/256 MB
    BIOS: Award Plug and Play Flash ROM BIOS with ACPI support for PC98 / Windows 98
    On Board I/O: 2 Serial Ports (UART 16C550 Supported)
    1 Parallel Port (SPP/EPP/ECP Supported)
    2 Floppy Drive supported (1.2/1.44/2.88MB)
    2 Channe IDE (PIO Mode 4 and Ultra DMA/33 Bus Mastering Supported)
    2 USB ports supported (Universal Serial Bus)
    1 PS/2 Mouse Port
    1 PS/2 Keyboard Port
    Real Time Clock: Built-in ASIC
    Battery: 3V Lithium Battery
    Green Function: Yes
    Connector: IrDA, Wake On LAN,SB-LINK,Wake On Modem
    Board Size: 202mm x 305mm, ATX Form Factor
    THATS THE SPECIFICATIONS ONT EH MOTHERBOARD SO ...
