Graphics HD5970s in crossfire. (Possible) Stupid Question.
Discussion in 'Hardware' started by ZortB, 27 Aug 2010.
  1. ZortB
    ZortB What's a Dremel?
    23 Apr 2009
    Have just picked up a ridiculously cheap second HD5970 on ebay to crossfire with the one currently in my setup. Do I need a connector to join the the 2 cards together, like i did with a previous sli setup? If so where can i get one from?
    I've checked the ATI website and the websites of my usual retailers (Scan, Overclockers, Ebuyer) but no mention of them. I didnt get one with the fist GFX card and there was only a sli connector with the mobo.
    Thanks in advance for what i suspect is a blindingly obvious answer.
  2. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    Crossfire and SLI connectors are supplied with the motherboards if they support the technology.
    What motherboard do you have, does it support crossfire?
    As if i recall only the x58 chipset supports both.
  3. registeredlandmine
    registeredlandmine What's a bit-tech?
    19 Jul 2010
    Yes, they sometimes include them with mobos and sometimes with the cards, if your motherboard didn't come with one are you sure its capable of crossfire?
    click here
    If you are folding or what every your doing (hopefully not just gaming), you don't always need one.
  4. ZortB
    23 Apr 2009
    The mobo is a gigabyte ex58 extreme. It is crossfire capable.
    Thanks for the replies and thanks for the link. :thumb:
    Yes, the main purpose is gaming, used to fold but it got expensive after i killed a couple of GFX cards (Still sob just thinking about them!).
  5. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Out of interest, what monitor resolution are you running?
    I have read that crossfire 5970's doesn't really have any benefit unless running at very high resolutions but I could be out of date on this.
    Edit: here is a picture of the connector you need...
  6. Rat1sully
    Rat1sully At Least Skt478 Never Broke
    29 Apr 2009
    i have to wonder in that pic where the upper cqard is drawing it's cool air from
  7. Wicked_Sludge
    Wicked_Sludge My eyes! The goggles do nothing!
    15 Aug 2010
    that was my first thought too...:eeek:
  8. sleepygamer
    sleepygamer More Metal Than Thou
    24 Apr 2010
    Especially in that mobo! I mean, it's got more than enough PCI-E slots to keep them an extra slot or two apart.
  9. Pete J
    Pete J Employed scum
    28 Sep 2009
    Technically you don't need a crossfire bridge, but the potential performance of the cards will be severely reduced IIRC. Go get one ASAP :) .
  10. Mraedis
    Mraedis What's a Dremel?
    5 Sep 2009
    Aren't CFX bridges delivered with every 5970? =/
  11. Fingers66
    30 Apr 2010
    The article that picture is from (Guru3D) does say that your case MUST have very high airflow exactly because of this.
  12. murraynt
    murraynt Modder
    6 Jun 2009
    I have one spare if you want.
  13. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    The 5970 pulls its air from the back of the card through two vents. Or at least, mine does. Bear in mind that the card never uses 100% of the fan when setup automatically to keep noise down, but overriding this causes the card to stay in the 30's in terms of heat output, so an override on those two plus good airflow should be fine. :)
  14. ZortB
    23 Apr 2009
    Thanks for the response guys.
    I want the second card as im running three 1920x1200 monitors with eyefinity(5884x1200 with bezel compensation), and if i'm honest, i'm a bit of a max settings freak (I know, e-peen and all that):D
    I definitely didn't get a bridge with the card.
    murrynt. Thanks for the offer but i've already ordered one off ebay.
    As for the air flow. I'b building a custom case and plan to w/c everything, my temporary case always has the side off so no airflow issues there.
  15. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    That's interesting and a bit disconcerting, which reseller brand was it?
  16. ZortB
    23 Apr 2009
    Sapphire. Could've been unlucky with mine. When i got the card i didn't look for the bridge as i wasn't planning crossfire at the time.
  17. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    If you're really concerened about the bridges, I believe I have 2 floating about, yours for postage.
  18. sleepygamer
    24 Apr 2010
    I have a pair that came with my motherboard, too. I don't intend on using them any time soon.
    Although soon I may have a use for them when I can finally get this money together. >.>
