Modding HDD Box (no raid box)
Discussion in 'Modding' started by Sunnysky, 27 May 2008.
  1. Sunnysky
    Sunnysky What's a Dremel?
    27 May 2008
    Hi
    first of all this is my first post, so im not sure this is the right place for this post. :D
    ok
    here it goes:
    HDD Box 4 X 500gb (no raid)
    the meaning of this box is, that i have got 4Hdd's from Lacie
    http://http://www.lacie.com/us/products/product.htm?pid=11050
    there is 1 problem, it is using big power adaptors
    so i need to find a way to use only 1 power source
    and my server has only 3 USB connections
    ive made a drawing to show u what i like to make
    HDD's to Lan version
    http://users.telenet.be/section_8/hdd_box.JPG
    (warning: image is kinda big)
    HDD's to USB version
    http://users.telenet.be/section_8/hdd_box2.JPG
    this could work perfectly, but i want to make sure if there is any other way to do this
    its like making a cheap raidbox without the raid
    but the usb to lan convertor is woking on usb 1.1
    or i can say that i dont use the USB to LAN convertor and use a usb hub
    the USB hub can be cheaper and more usefull
    i have a 10/100 network router with 1 spare connection left
    and the hdd's are shared on the network on my server
    so it does not matter if it goes by lan or usb, it will be shared anyway
    the tools:
    http://www.usbgear.com/computer_cab...-4XU1&cats=102&catid=2345,112,508,102,120,137
    USB to LAN
    http://www.tigerdirect.com/applicat...pNo=1699339&SRCCODE=WEBINKPLP&CMP=OTC-INKTOMI
    SATA to USB
    http://www.usbgear.com/CA4H4M.html
    USB Hub
    greetings Sunny
  2. mattthegamer463
    26 Nov 2004
    Nice design, I like it. And welcome.
    I hope all those SATA->USB and USB->LAN adapters daisy-chained together will work, I would just think that having that many adapters could result an incompatibility.
