Other HDD Cloning Advice
Discussion in 'Software' started by ChildOfMana, 9 Feb 2012.
  1. ChildOfMana
    ChildOfMana What's a Dremel?
    9 Jan 2012
    Hi guys,
    I’m looking for some recommendations for (and advice about) a decent disk cloning tool to use. The thing is, it has to be free – I can’t afford to use a commercial solution unfortunately.
    I’ve heard good things about Clonezilla. Anyone have any experience with this?
    Basically all I want to do is clone the system reserved and C: partitions of a Windows 7 install on a laptop hard drive so, when things inevitably go downhill in the future, I can just deploy the image to the drive for a clean start without too much messing about.
    I assume this is possible? I’ve not had any experience in the past with disk cloning though. What happens with regard to the MBR etc? Will that be cloned (and subsequently restored) too?
    I’m also under the impression that any unused space on the drive is heavily compressed to make the image as small as possible. So, say, cloning a 100Gb partition with only 20Gb used and the rest free space wouldn’t actually weigh in all that much more than 20Gb? Is that right – or is it literally a bit-for-bit thing?
    There is one more caveat – the only external drive I have with space enough to store the image is formatted to Ext3. So whatever tool I use would have to support reading from and writing to Ext3. There’s too much important data on that drive to reformat it to NTFS unfortunately. It’s a WD MyBook 500Gb USB 2.0 drive if that matters.
    Thanks in advance.
  2. Chairboy
    Chairboy I want something good to die for...
    10 Jun 2004
  3. ChildOfMana
    9 Jan 2012
  4. law99
    law99 Custom User Title
    24 Sep 2009
    I've heard good things about clonezilla, but it's never worked for me. And it's not because I don't know what I'm doing. It's been hardware problems. I haven't needed to use it though, so never dug any deeper.
  5. Chairboy
    10 Jun 2004
    If you can see it from Windows then it probably will be able to back up the image to it. I don't know for sure as I've never tried it :)
