Does anyone know if it's alright to connect 2 LED's in parallel to the HDD LED header on a motherboard? I want the one in the front of my case and one elsewhere for a tiny mod I'm planning Cheers
Yes, it will work fine (I do it) Two LEDs in parallel should come out to ~40mA The HD can handle up to ~90mA
Not sure I follow that, Zap. Doesn't the stock led have a series resistor or some current-limit system on the mobo? Then adding an extra led in parallel with the original will give the same current divided between the two?
The motherboard does have a resistor. But remember that the resistors only takes up the Extra voltage left over. For example: Take a 2volt LED +5volts----/\/\/----LED---GND There will be 3 volts that the resistor will absorb. BUT take the same LED and put two in parallel on one resistor +5volts----/\/\/---+-----LED-----GND ..........................+-----LED-----GND The two LEDs have 2 volts.. but in parallel the voltage drop will be lower (around 1.2-1.5volts) so the voltage across the resistor will increase, increasing the overall current load. But it's nothing to worry about.
I get your drift, but the Vf change isn't much at all in those circumstances (leastways, not with the Kingbright leds I usually get). With these common Kingbright reds, Vf at 20mA is 2.0v, so a 150R resistor is spot-on at 5v supply. Add another parallel led, current through each is around 10mA, and from the chart, Vf will only have dropped to 1.9v. Put that back in the (Vs-Vf)/R equation and the total current has only gone up to 20.7mA, with each led now getting 10.35mA. So they'll be a tad dimmer, but bright enough for case leds & no danger of blowing the HDDA electronics.
One transistor, one resistor, problem solved I am planning to do this for my own case, perhaps. There are six HD LEDs on the front of the case, but I might use them for something else instead (CPU meter perhaps?). So, I was thinking I might do lots of backlit HD indicators for my 8 channel RAID (don't have 8 HDs yet though), using a transistor. Side note: if you use several LEDs in series and their combined voltages add up to the supply voltage (e.g. six 2V LEDs in series from a 12V supply) you don't need a resistor. MoJo
Thanks Zap, that was basically the plan. Instead of cutting the IDE cables though, I intend to just use the spare connector as each of the 8 channels can only take one hard drive anyway. MoJo
