Modding hdd mod
Discussion in 'Modding' started by ahug4122, 11 Dec 2004.
  1. ahug4122
    ahug4122 What's a Dremel?
    16 Sep 2004
    how do i put a window in my hdd is it possible
  2. dmcm01
    dmcm01 Banned
    15 Aug 2004
    /off topic
    TWAIN - Technoligy without an intresting name
    i dunno how you would go about it, but i have seen it done, i think it would require two idendicle hard drives and a dust free work space.
  3. adamjones01101
    adamjones01101 What's a Dremel?
    29 Jul 2004
    why two? i believe there is a guide to windowing a hard drive right on Bit-Tech. :search:
  4. Mace
    Mace Ohh, it stings.
    9 Dec 2003
    Was reading something before and the person used 2 hard drives... molded the window on one, the crappy one that they didn't want anymore... and then quickly and cleanly put it on the new good hard drive...
  5. Zephyr
    Zephyr Go V-Boy, Go!
    1 Oct 2004
    I can understand how two hard drives would make it easier, but it still seems extremely risky to me to do. The most obvious warning is to backup all your files first :p, and do it extremely quickly. I would say vaccum really well, to try to minimize the dust in the air first, but I would imagine that vaccuming would stir up the dust as well, so maybe that wouldn't be such a good idea. Good luck if you do it, be sure to post your success :thumb:
  6. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    From what I've read you should use an older harddrive with platter density lesser than 40 gb (i think that's the number) because otherwise even if you don't have any dust get on the platters because they lose the the little thingy that keeps them centered they'll stop working after a while. Other than that I would try and work in a plastic bag or something that's pretty clean.
  7. Yerg2k
    Yerg2k What's a Dremel?
    7 Dec 2004
    Three words for ya:
    Laminar Flow Hood.
    If you don't know what that is, it is a HEPA filter with fans. People use these to create dust-free workspaces. Make sure you wash your hands well too, before doing any HDD modding. And if you don't know what you're doing, you're probably better off not doing it.
    Flow hoods are great when you want to do something requiring very little dust, such as modding hard drives or culturing mycelium. Don't ask.
  8. I'm_Not_A_Monster
    I'm_Not_A_Monster Hey, eat this...
    22 Dec 2003
    whats that?
  9. evertek
    evertek What's a Dremel?
    5 Dec 2004
    I think I heard this trick at extremetech.com, but turn your shower up nice and hot and get the bathroom steamy, and that will take the dust out of the air, just make sure you turn it off so your not working with too much moisture. Then you can open the HD up, and put it in a bowl with syran wrap while you work on the top.
  10. Zephyr
    1 Oct 2004
    Culturing mycelium: creating funny colors with bacteria?
    [/OT]
    I thought about advising a Ziplock bag, but they are pretty static-ey, so I wasn't sure how that would turn out.
  11. G4m3R_X3r0
    G4m3R_X3r0 What's a Dremel?
    3 Sep 2004
  12. RR5
    RR5 What's a Dremel?
    7 Dec 2003
    You also can google search "hdd window" or "hard drive window"
    Have fun. I cant wait until the manufacturers actually make hdds WITH windows.
  13. I'm_Not_A_Monster
    22 Dec 2003
    don't they make static-free ziplocks?
  14. |I.H|
    |I.H| What's a Dremel?
    4 Dec 2004
    Don't think so..... :duh: :wallbash:
  15. I'm_Not_A_Monster
    22 Dec 2003
    not ziplock brand but the zipping dealie?
  16. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    i would never to do it, did about 1/2 years ago, just sata hard drives 200gb.. 2 off them.. too much to lose.
  17. I'm_Not_A_Monster
    22 Dec 2003
    there was a mod that was a little over my head, from what i understood of it (i think) the IDE drive has seperate movement wires and data wires. if you modded a puny HDD and connected the right IDE wires, you could create the illusion of your 200GB drives.
    if the modded one was in front of your "real" drives, it would look cool
  18. RR5
    7 Dec 2003
    Static is the least of your worries if you open the hard drive. A dust particle landing on the platter will cause data loss.
    But I'd assume you could fabricate a tunnel of sorts using a vacuum with the best filtration you can find. Something like this
    Code:
    ( <- suction flow) [HDD] ( <- suction flow)
    And then have the drive in contact with an earth grounded surface. Or get the anti static wrist straps and clamp a few to the drive or like a metal cookie sheet.
