Modding HDD mounts
Discussion in 'Modding' started by H4wk1e, 9 Dec 2006.
  1. H4wk1e
    H4wk1e Minimodder
    7 Jan 2004
    has any one got HDD mounts that mout A Hard Drive in the CD-Rom Bay.
    If so where did you get from? :)
  2. specofdust
    specofdust Banned
    26 Feb 2005
    You can get coolermaster 4in3 units that I think fit in normal PC's too. Other then that, there are plenty of 3.5" in 5.25" bay adaptors in most online shops case sections. There are ones designed to cool available also but they cost around £20 and up.
  3. maxinflixion
    maxinflixion What's a Dremel?
    20 Aug 2006
    I picked up a few for less than $5 on Ebay... Just simple brackets...
  4. H4wk1e
    H4wk1e Minimodder
    7 Jan 2004
    not really sure what to search for, what are there correct name?
  5. specofdust
    specofdust Banned
    26 Feb 2005
  6. H4wk1e
    H4wk1e Minimodder
    7 Jan 2004
    cheers, thanks alot, just found some on e-bay
    click here this be good as my cd-rom Drive in the 5.25 bays are on screew roll
