HDD / OS problem
Discussion in 'Hardware' started by jake^the^cake, 6 Apr 2004.
  1. jake^the^cake
    jake^the^cake What's a Dremel?
    1 Oct 2002
    Yarr, i got a problem!
    I used partition magic 7 to format the partitions i had for linux and the swap. Now the computer can't find the OS, the OS is win2k and it's on C:
    What to do? :(
  2. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    sit back, have a beer and then just fix the mbr
  3. RTT
    RTT #parp
    12 Mar 2001
    Put your win2k disc in, go to the recovery console and run fixmbr :thumb:
  4. jake^the^cake
    1 Oct 2002
    Is there any way to do it without the CD? Its my school laptop, so win2k was installed at school, dont have any cd at home, and its holiday for a week atm, so i cant get it from school either...
  5. Crash
    Crash What's a Dremel?
    2 Nov 2002
    Unlucky :wallbash:
    Are you sure school will be over the moon about you deciding to change the partitions on their property? :worried:
  6. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    How did you get on with the BOOT CD last nighe jake?
    Hope it worked.
