Modding HDD question
Discussion in 'Modding' started by -SilentNight-, 22 Feb 2004.
  1. -SilentNight-
    -SilentNight- Hardcore pro gamer
    24 Jan 2004
    Hello. I got a litle problem, its HHD i had now it horizontal, so can i put it to vertical? with out damaging HDD
  2. Etacovda
    Etacovda What's a Dremel?
    4 Nov 2003
    You might want to use
    Code:
    Several people have done this, as long as its pretty much perfectly vertical or horizontal you'll be fine. Think of it as a spinning disc, cause thats what it is - for balance, it has to be vertical or horizontal.
  3. Tau
    Tau Sharingan!
    17 Nov 2002
    I'm pretty sure it doesn't matter what angle you mount it at, as long as you don't move it around while its spinning. Certainly putting it vertical shouldn't matter.... maybe i've misunderstood what you're trying to do from your diagram
  4. Darv
    Darv Bling!!
    12 Aug 2002
    If its a really old HDD then you probably wont want to do it.
    But for anything more modern (probably something from the last 5/6 years or newer) then it is fine to have it anyway up or any angle you like.
  5. Fraggster
    Fraggster What's a Dremel?
    30 Dec 2003
    vertical is hard on the drive one would think
  6. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    Ipods any one? shock is hard on the drives more than the orientation, as the drive arm already operates free of gravity
  7. PC JUNKY
    PC JUNKY Banned
    7 Jul 2002
    I have had both my 60GB and 200GB hard drives laying in virtually every different direction and angle, and I haven't had any problems with my hard drives yet. So if this is what your asking if you can do I say GO FOR IT your drives should be fine, but as stated above while your drives are on/spinning DO NOT MOVE them or it will be your fault that they get screwed up.
  8. ohcyt
    ohcyt What's a Dremel?
    7 Jan 2004
    I've read once that when you use a HDD lying flat for a while, then the spinning mechanism wears out to that movement, and when you change the angle of the drive the spinning mechanism breaks down...
    it's just something I vaguely remember reading somewhere, but I really don't know if it's true =)
  9. PC JUNKY
    PC JUNKY Banned
    7 Jul 2002
    Sounds reasonable, but I will say that I have never heard anything about this kind of problem.
  10. blackflag
    blackflag I Kill Dremels
    16 Oct 2003
    I don't think there should be anything to worry about. We use IBM PCs at work ( :sigh: ) and they all have different directions that the HDD is mounted (horizontal as well as vertical). Granted, it may be difficult to determine the effects that position has on the HDD as IBM's fantastic "DeathStar" line of HDD's die before any extended period of use. :hehe:
  11. -SilentNight-
    24 Jan 2004
    thanks by answers i got modding-fever so? :dremel: lets see what we will got 6wks to lans wich has modding competition....
    im thinking fit and tall tower wich i do then i put on to table with table stands im thinking i will do it from plexi.. we will see what i will have
  12. 3N1GM4
    3N1GM4 What's a Dremel?
    23 Jun 2003
    all points made, it kinda makes sense why it wouldnt work... but i have never heard of any problems like this... :eyebrow: so who knows really
